Question about Gateway Computers & Internet
What wires go to where from the powerbox on a Gateway 2000 ATX celron. They are labeled (P1 to P6)?
  • 54 Answers
Can you give me more info please and i will try to help
Posted on Jun 29, 2009
Having problems with Bestec ATX-300-12z power supply.
Replacing the Power Supply in HP Pavilion p6000 p6 1000 and p6 2000... This is a common power supply that can be purchased just about any computer retailer - BestBuy, MicroCenter, Amazon.
Very cheaply priced, very functional. Even the generic brands.
Hope this help.. have a great day. OH, make sure you at least match the current power supplies WATTs and it's connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Nov 14, 2012 | HP ATX-300-12Z, ATX-300-12Z Rev. CDR, HP...
How to put a powerbox in
Powerbox??? What kind of powerbox? How to put it in what? Good luck finding that pic!
Mar 19, 2012 | Cars & Trucks
Not sure which plugs go where on the bestec atx300 power supply for gateway computer. remopved the old powere supply, but don't know which plug goes where on the new one.
I'll assume that your old PSU is also an ATX. First, the plug that has a few dozen wires arranged in a rectangle goes into the MB. Your PSU's ATX connector may be split into 2 parts: the AT portion and a square portion with 4 wires. Together, they make an ATX plug. You'll find some tiny plugs with 2-3 wires for your onboard fans. You might find a few slightly larger flat plugs with 4 wires for old floppy drives. The rest should be the regular MOLEX plugs and slim SATA power plugs for your drives.
Aug 15, 2011 | Gateway Bestec ATX-300-12EB3 305w Power...
Where does the trailer battery charging wire connect to on a 2000 silverado 2wd w/o trailer package hook in?
UNDER THE HOOD, REMOVE THE LID OFF THE POWER DISTRIBUTION BOX. THERE SHOULD BE TWO STUDS STICKING UP, PROBABLY TOWARD THE REAR. DISCONNECT THE NEG. BATTERY CABLE. YOU WILL NEED A 30 AMP AUTO RESET " STUD STYLE" BREAKER. WITH 2 HOLES FOR MOUNTING. MOUNT THE BREAKER ON THE FENDERWELL NEAR THE POWERBOX. USE 10 GAUGE BLACK WIRE. WITH WIRE TERMINALS. GO FROM THE POWERBOX, TO THE BREAKER & FROM THE OTHER SIDE OF THE BREAKER TO THE REAR OF THE TRUCK TO THE TRAILER RECEPTACLE. I WOULD PUT THE WIRE GOING TO THE REAR IN A PLASTIC WIRE LOOM PROTECTOR, AVAILABLE AT MOST PARTS HOUSES BEFORE INSTALLING UNDER TRUCK. FASTEN WIRE WITH NYLON WIRE TIES AWAY FROM ANY EXHAUST PIPES, CAT CONVERTERS, ANYTHING SHARP OR HOT. FASTEN SECURELY IN TRAILER RECEPTACLE, RECONNECT THE BATTERY.
Jan 10, 2011 | 2000 Chevrolet Silverado
MOTHERDRIVE FOR CELRONE
A Intel Desktop Board D845GERG2 - motherboard - micro ATX - i845GE - Socket 478 will be good.
Dec 06, 2010 | Intel Celeron 2.4GHz-D (CELROND24GHZ)
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
The console display on my Horizon Fitness T63 treadmill won't stop scrolling/flashing the programs (P1-P6) and will not start up.
Sounds like there is a stuck button on the console, or possibly a loose ribbon cable inside the upper console maybe?
Oct 21, 2010 | Horizon Fitness T90 Treadmill
Power Supply Bestec ATX-250-12E Rev.P6
Normally if you open the PSU up warranty will be void. ( if it's Under Warranty). if not once you open the unit the fuse's are located right nest to the power input.
Jan 01, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Computers & Internet Logo
51 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
