Question about Honda Garden
I do have a honda EXHA2425 Pressure washer and my pump leaks water .How can i glue it plz
  • 47 Answers
If its comming from between two metal parts, you need to dissassemble them to see if it takes a gasket or o-ring. o-ring is most likely, take it out and to a hadware store to find a new one same size, glue will not work because of the pressure involved.........
Posted on Jun 29, 2009
Excell 2400 exha2425 has no compression
take off the pump unit start the engine, and see if it runs good if it does then change your pump if not then you must have busted a piston ring you can take it to any auto mechanic to replace the ring.
Oct 09, 2014 | Garden
Water leeks out of pump
Ware on the pump dose it leak because it dose have a tempature sensitive blow out valve 145 degrees water temp . And what kind of pump is on this mechine CAT MITI M or simpsion al though it could be a lot of other brands from all over the world because no one builds it all with power washers they may put there name on it but use parts from all over
May 20, 2012 | Honda Pressure Washer PSI 3000
My 2500psi pump leaks what can i do?
sounds like the seals and o'rings are worn and causing the pump to leak water.also one of the pistons might have a crack in them.dis assemble the pump and inspect the pistons,if none are cracked,then replace all the o'rings and seals.this should stop the pump from leaking.
Jan 15, 2011 | Honda Pressure Washer PSI 3000
Oil milky white in pump
it may have a slow water leak inside the pump.
change oil and monitor the new oil.
if it goes milky the next time you use it then it has a bad leak and the seals will need to be
replaced,otherwise the bearings will rust & seize
Dec 18, 2010 | Honda Pressure Washer PSI 3000
Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Jul 22, 2009 | Honda Garden
The tubing from the gasoline is not connected
Devilbliss / Excell pressure washers in this model number range use a Honda GC160 engine. Information on this engine can be found here:
http://www.excellpressurewasher.com/documents/pdf/gc160.pdf
This web site also has information about the pump and related parts just look for your model number. I find that pressure washer manuals have very little information about the engine. Small engine / mower repair shops in your area will be happy to give you free information about the where the fuel line attaches. Your engine has a black plastic fuel pump with hoses going to tank and carb. This fuel pump is powered by engine crank/vacuum purssure so there is a third hose from the fuel pump connected to the engine block. Good luck on your repair and email if you have a question or if you have a different engine than mentioned above.
May 09, 2009 | Garden
Water leaking from underneath after washer drains
Hiya........... have a good look at the door seal for any visible tears... do it with wet hands... and the electric off!! If you cant see anything... Have a look at the pump couplings.. for any visible signs if leaking!
Get back with the results
regards Faggly
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Garden Logo
385 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
