Question about John Deere 3010,3020 Tractor Basic Carburetor Repair
Tech says i need a new carburetor marvel schebel usx 49sl - should i fix it, or replace it? trying to determine if there is alternative carb for this tractor.
  • 33 Answers
There should be no reason why you can't rebuild it,as long as casing isn't cracked
Posted on Jul 04, 2009
Installing new carburetor. How do I fix the paper gasket between the block and the carb. Adhesive?
dont fix replace trying to fix damaged will cause failure down line just replace with new
Sep 11, 2016 | Cars & Trucks
Carburater replacement
  • Why do you need a new one?
  • Details in the main link for cleaning and replacing.
  • Carburetor replacement parts for 2006 Kawasaki KFX50 ... www.2wheelpros.com/oem-parts/2006-kawasaki-kfx50-ksf50-a6f... Original 2006 Kawasaki KFX50 (KSF50-A6F) Parts. Search Carburetor parts using manufacturer microfiche assembly diagrams.
  • 2006 Kawasaki KFX50 KSF50A CARBURETOR Parts, 2006 Kawasaki ... www.bikebandit.com/oem-parts/2006-kawasaki-kfx50-ksf50a-carburetor/... 2006 Kawasaki KFX50 KSF50A CARBURETOR Parts at BikeBandit.com. The Web's most trusted source for 2006 Kawasaki KFX50 KSF50A CARBURETOR OEM Parts.
  • 2008 Kawasaki KFX50 (KSF50-B8F) - CARBURETOR ... - ... www.2wheelpros.com/oem-parts/2008-kawasaki-kfx50-ksf50-b8f... 2008 kawasaki kfx50 (ksf50-b8f) - carburetor ... 2008 ksf50b8f (932) schnee white; air cleaner; battery; belt converter; carburetor(b8f/b9f) chassis electrical equipment;
  • Kawasaki ATV Parts 2006 KSF50A6F KFX50 CARBURETOR Diagram www.partzilla.com > Kawasaki Parts > Kawasaki ATV Parts Search for Kawasaki ATV Parts 2006 ... Parts / Kawasaki ATV Parts / 2006 / KSF50A6F KFX50 Kawasaki ATV Parts 2006 KSF50A6F KFX50 CARBURETOR Diagram ...
  • 2008 Kawasaki KFX50 (KSF50B8F) Carburetor(B8F/B9F ... www.kawasakipartshouse.com/oemparts/a/kaw/500b50d3f8700223e47963d1/... Shop our large selection of 2008 Kawasaki KFX50 (KSF50B8F) Carburetor ... Kawasaki; ATV; 2008; ... or any Replacement Parts! Kawasaki Parts House is ...
  • Kawasaki KFX50 KFX 50 Carburetor Carb 15003-S004 Fuel Gas ... www.amazon.com > ... > Parts > Fuel System > Carburetors Kawasaki KFX50 KFX 50 Carburetor Carb 15003-S004 Fuel Gas 2003-2006 New OEM
  • Kawasaki ATV Mini KSF KXF 50 Carb Carburetor Used Parts ' ... www.ebay.com/sch/sis.html?_nkw=Kawasaki+ATV+Mini+KSF+KXF+50+Carb... Find best value and selection for your Kawasaki ATV Mini KSF KXF 50 Carb Carburetor ... Kit Carb Repair KFS 50 KFX ... 2006 Kawasaki KFX KSF 80 Carburetor ...
  • 2006 kawasaki carburetor ' eBay www.ebay.com > Search > 2006 kawasaki carburetor Refine your search for 2006 kawasaki carburetor. Refine. more Format ... Kawasaki KFX 400, 2003-2006, Carb / Carburetor Repair Kit - KFX400 ... $34.50. List price: ...
  • Go to Bing homepage
    Jul 09, 2016 | kawasaki 2006 KFX 50
    I took scooter for a ride everything worked fine get back to garage and fuel is leaking out of carborator to which it drained the fuel tank. Do I need a new carb or what's the problem.
    Jason, You can replace carburetor or have the old carburetor rebuilt to fix your gas leaking problem, either float is stuck or if carburetor equipped with a solenoid shut off, are the actual problem likely.
    Check the attached links,instruction and guides, Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Carburetor Rebuild Cleaning Instruction Video
    3 50cc Scooter Moped Carb Theory and Common Carb Problems
    How to clean scooter carburetor
    rebuild scooter carburetor Google Search
    Jun 18, 2016 | Motorcycles
    How do I fix an echo srm 230 weed eater carburetor
    Get the carb kit and replace all. Make sure that you tighten all the screws so there are no air leaks and cross your fingers.
    Those cards are a royal pain in the ----
    Aug 25, 2015 | Echo Garden
    Hi i have just bought a brand new but second hand
    Your brand new secondhand USX-800 may be no good. From your description it seems you have done everything possible to get it to work
    Aug 07, 2013 | Audio Players & Recorders
    1985 Yamaha V-Max carb overhaul
    Hi, Brock02 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one.
    For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
    Yamaha Max Carburetor repair
    Carbs leaking Here is how to fix it
    http://www.vmaxoutlaw.com/tech/VMX12-Service-Manual.pdf
    OEM parts for Yamaha
    http://www.vmaxoutlaw.com/tech/owners_manual.pdf
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
    May 31, 2011 | Yamaha V-Max Motorcycles
    I have a Marvel-Schebler carburetor, Model Tsx. My carb had needle brings in throttle shaft. When I removed throttle shaft the needle brings fell out. The kit does not have new bearing in kit. What is the...
    There are no needle bearings in the carb, they came from someplace else. And I suspect a connecting rod. The only place I can think off where they could have come from. And I'll tell you why. I had a 66 Saab, 3 cyl, 3 carbs, 2 stroke,4 speed on the column, front wheel drive, rack and pinion steering, way ahead of it's time. Neat little car. Never got stuck. But, I had a problem once with a piston slapping, I could stick my finger in the spark plug hole and feel the piston come up and fall down, I said what the? So I replaced the engine, I had a spare. Took off the head and the top of the piston was just peppered with needle bearings from the wrist pin. How they got up there , I don't know, but they were there. Hope this helps.
    May 05, 2010 | John Deere 3010,3020 Tractor Basic...
    I have an onan 5500 gas generator that wont start
    What is the model? Chances are the carb needs cleaning or replaced.
    Sep 21, 2009 | Watts Onan Portable Generator - 4000 ,...
    No Gas to Primer Bulb
    It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
    May 21, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
    John Deere 3010,3020 Tractor Basic Carburetor Repair Logo
    183 people viewed this question
    Top John Deere Garden Experts
    Phil Walker
    Phil Walker
    Tim Whalen
    Wayne Fellows
    Wayne Fellows
    Are you a John Deere Garden Expert? Answer questions, earn points and help others
