Question about Garden
Was roto-tilling up the garden, shut pto off at end of row, when went to start it again, pto wouldn't start. Dash board indicator light says pto is on but it isn't running. Also, belts are all fine. Any help would be greatly appreciated
  • 61 Answers
Ck fuses and ck for 12 volts at pto
Posted on Sep 06, 2009
Was running fine, engine just stopped - plenty of gas and oil, tilled several garden rows fine and stopped running?
If no spark no crank check saftey interlock switches. The driver present under the seat is a common failure.
Additional interlock saftey on the PTO
Hope this helps?
Nov 11, 2016 | Garden
PTO led on the dash lights up when i try to start the tractor. I replaced the PTO switch, but no luck. Its like the starter loop thinks the PTO is ON, but the switch is definitely OFF.
Sounds like something like the key switch is searching for a ground.Use a piece of wire hooking one end to the negative of the battery and touch the metal case of the key switch with the other end , turn the key and see if the pto light still comes on , Feedback from a bad ground can drive you crazy.
Jul 04, 2016 | Garden
Shut down problem
im betting the center pto is still engaged still , this is a safety system (no start with pto engaged) I come across once in a while , not many folks use the center pto so it gets forgotten till somehow the engage lever gets set there , or sometimes it sticks in too
that's the simple thing I can think of , it only gets more deep from there
Jun 24, 2015 | Garden
Ok so the problem,on my gravely zt 2250 is was mowing went to shut blades off and they kept on spinning and there also spinning when trying start engine replaced clutch twice still same problem
Sound like either the PTO relay is struck in run position or the PTO switch has failed and applying 12v to the PTO relay even in the off position.
IPLs for the Gravely ZT2250
Wiring_Diagram/10265/10261
Nov 24, 2014 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Husqvarna pto problem(?) disengaged blades to travel, would not engage after. Battery dead when checked after shutting off engine and wouldn't restart
Hi, first charge or replace the battery if necessary then check that the mower is charging the battery. The pto is probably fine but it needs battery voltage to engage. If the mower has stopped charging the battery may have had enough voltage to hold the pto in until you disengaged it but not enough to re engage it. Regards Phil.
Sep 06, 2012 | Garden
Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
May 17, 2010 | John Deere 6300,6300l,6400,6400l Tractor...
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
