Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Our 32 " lcd Element TV went black
We were using our new lcd 32" element tv and it just went black. We turned it off and then back on and it flashed with "Element Electronics" and black. Do you think we lost the screen or is on a standby mode. Looked in manual and it didn't help.
5 Suggested Answers
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
SOURCE: Element flx-3210 lcd tv
The new control boxes for the flx3202 are about $400.00
I have the same problem and its more than I paid for the ($378.00) element will give you an out of warranty exchange for the low price of $600 + and a 90 day warranty to boot What a great deal HUH hahahaha! anyone have the address for element electronics they will not give it out and its not on any paperwork I wanna mail this piece of **** back tp them in Pieces
Posted on Aug 12, 2008
  • 2187 Answers
SOURCE: how to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Posted on Sep 07, 2009
gopakumarg43
  • 75471 Answers
SOURCE: my sony trinitron 32" tv just went black and the
Hello
Six blinks of standby light in Sony TVs denotes the absence of horizontal oscillation.
No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
In most cases the Ic is foud defective. anyway check its soldering points for any loose contact, or bad solerings. Check the line drive transformer, a very little transformer soldered directly to the main printed circuit board, very close to the horizontal output transistor. Check its primary winidngs for open. If it gets open no horizontal drive signal will be present at the base of the horizontal output transitor, that also may the cause of horizontal stop.
Posted on Nov 20, 2010
Element 32 in tv
Element 32 in tv - Fixya
www.fixya.com > Forum > Flat Panel Televisions > Element
38 mins ago - element 32 in tv Need a code to run the volume and on off shaw direct sat. - Element Flat Panel Televisions question.
Remote Control Code for Element LCD TV -- & Direct ... - Fixya
www.fixya.com/support/t1101060-remote_control_code_element_lcd_tv
Remote Control Code for Element LCD TV -- & Direct TV Haven't been able to find the right code to program the - Olevia LT32HVM 32 in. ... It is annoying to turn the TV on and the volume with the Element remote and then have to use the ..... Need the codefor a 42 inch LCD TV model ELDTW422 to program our Direct TV ...
Element 32" 1080p TV (ELDFW322): Unboxing & Setup ...
? 6:40
https://www.youtube.com/watch?v=EKtjBnx6EG0
Mar 27, 2013 - Uploaded by PureLegit
This is a new video on this TV that I got from Element. If you go back on my channel you will see my first ...
Jan 20, 2016 | Element Televison & Video
Picture went black
Likely power supply failure, especially with the bad smell
Sep 10, 2012 | Element Electronics FLX-3211B 32 in. LCD...
My Element 32 inch tv has black screened.
hope I dont sound too crude, but have you checked the contrast and brightness controlls ?? they may be labled as 'picture options' or some other odd label...
does this tv have a LED, LCD or the older CTR display ?? If it is LED or LCD, then the light source that illuminates the screen are not working.. this light source could be damaged..
Sep 09, 2012 | Televison & Video
32" Element HD LCD TV screen often sticks to one
The tv have a long board called a LCD inverter board it is dying.This LCD inverter board help the tv LCD screen panel to have a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish a new long LCD inverter board for the replacement.
Oct 09, 2011 | Element Electronics FLX-3211B 32 in. LCD...
I have a Element 32"
Unfortunately, components need their black smoke.
Once the black smoke escapes, the component is useless.
(ok, that's a tech joke)
It should at least be easy to identify what components blew when you open it up.
Mar 09, 2011 | Element Electronics FLX3210 32 in. LCD TV
I have a black box appearing in my element hdtv flx3210 TV
Ur tv is still having captioning on.Used ur remote find a button said CC turn it all off like CC1,2,3 and TEXT 1,2,3 all off.Or go into ur tv menu turn it all CC1,2,3 and TEXT 1,2,3 all to off.U will not getting anymore black boxes appearing.
Oct 03, 2010 | Element Electronics FLX3210 32 in. LCD TV
Element electronics LCD, was on for several hours picture went blank, sound is still perfect. 12 hours later still no picture when turned on, great sound though.
Typically this failure is due to the backlight inverter going out. On this model of tv there were two runs with different parts. Open the back of the tv and open the control box. If you see a large black circuit board on the top, replace that one. If its tan then you need to take out the control box and remove the black plastic backing. If you're looking at the back of the tv the inverter will be on the left side of the control box. Its a long skinny board that has 8 black metal squares on it. Good luck and be careful.
Mar 14, 2010 | Element Electronics FLX3210 32 in. LCD TV
32" flat screen that went black
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Element Electronics FLX3210 32 in. LCD TV
Element LCD TV owners - Using the VGA port may crash your TV!
I bought two of these tv's and they worked fine,I hooked up a computer to both of them and blam smelt smoke in one and the other wont come on either. The computer takes them out. It is a common problem with this TV.
Nov 01, 2009 | Element Electronics FLX3210 32 in. LCD TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
