Question about MSI KM4M-V Motherboard
Cmos checksum error defaults loaded - MSI KM4M-V Motherboard
  • 2,404 Answers
Make sure the battery your using is brand new. If it is then go ahead and get into the Bios and make sure the date and time is set properly. Once you do that then go ahead and save the changes and exit.
After this go ahead and see if the CMOS exit checksum defaults comes up if not then go ahead and turn off the computer and unplug it. Then after about 5 minutues plug the computer back up and turn it on and if the message doesn't come up then its resolved.
If the cmos checksum error comes back up then try a brand new battery, should be a 2032 battery and then go thru the same steps in setting the date and time and save changes and exit and if the message doesn't come back then unplug the system again and leave it unplugged for 5 minutes. Now plug it back up and if the message stays away the problem is resolved. it the message comes back then that means the motherboard isn't reconizing the batteries and the motherboard would need to be replaced.
Posted on Jun 29, 2009
    Scholar:
  • 84 Answers
CMOS checksum error can be a sign of 1) bad RAM modules or 2) faulty BIOS battery.
Have them checked or replaced as necessary.
Hope this helps.
4 Suggested Answers
  • 193 Answers
SOURCE: Bad BIOS checksum.... CMOS bad checksum errors
u need to chnage the c-mos battery>and try this first unplug teh c-mos battery and replug it and check if its not works then chnage it rate me solved if its helps thx
Posted on Nov 15, 2007
SOURCE: CMOS Error
If your CMOS batt is ok, then try flashing your BIOS
Posted on Feb 08, 2008
steve6375
  • 395 Answers
SOURCE: Asus P4B Motherboard
Press DEL to enter setup and set Reset to Defaults in Exit menu. If you have USB keyboard, make sure you enable Legacy USB and USB keyboard settings, save and exit and reboot.
Posted on Aug 08, 2008
Dell Inspiron 530. At start up gives CMOS checksum error defaults loaded. Options press F1, F2 or F12 computer does not react. Has new CMOS battery. RAM OK. Did CMOS clear and password reset. What else can...
When a Power Supply is plugged into power, there is a constant 5 Volts present. The 5 Volt Standby Power.
You press the Power On button.
This in turn presses against the Power On switch, located inside it's plastic assembly.
The Power On switch is a Momentary Contact Switch.
Temporary closing it activates the Soft Power On circuit.
A 5 Volt circuit that utilizes the 5 Volt Standby Power.
The Soft Power On circuit 'excites' the Power Supply, and turns it on.
(Sounds like a seedy novel)
The first chipset (Integrated Circuit) to receive power is the BIOS chipset.
The Basic Input/Output System program is initialized.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, and hands the computer over to the Operating System.
A checksum is computed as an error-detecting code, to protect the BIOS settings stored in CMOS.
Each time the computer is turned on, this number is re-computed; and checked against stored values.
If they do not match an error message is generated, to tell you the CMOS memory contents may have been corrupted; and therefore some settings may be wrong.
Your BIOS assumed the settings were incorrect, and loaded BIOS default settings; stored in BIOS.
(Default = factory settings)
CMOS Checksum Error Defaults - Loaded
New battery? Nope didn't help.
Clear CMOS, and password reset? Nope didn't help.
Leaves Virus as the problem, or hardware component/s on motherboard; are bad.
My thoughts?
Bad motherboard.
("BAD motherboard. NO,...........you know you have been bad,....don't give me that look. You're a bad motherboard."
Lol!)
That's my diagnosis.
(Unless you put the CMOS battery in upside down.
+ goes UP)
Regards,
joecoolvette
Mar 17, 2013 | Dell Computers & Internet
Compaq Presario 2500 stopped loading windows XP with a prompt STOP: c0000221 {bad Image Checksum} The image COMCTL32.dll is possibly corrupt. The header checksum does not match the computed checksum.
This error is not the same as a CMOS Checksum Error, which refers to corrupted values of the CMOS settings, the ones you set through the BIOS setup program. This error means the contents of the BIOS code itself are damaged.
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start control panel date and time you can make your adjustments to the date and time from there also right click on the date and time on the bottom toolbar (bottom of screen) you should see Adjust date and time tab
hope this helps you
Sep 09, 2011 | Compaq Presario 2100 and 2500 ,NX 9000...
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
Press F2 to load default values and continue
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
Cmos checksum error & keyboard not function
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOS settings stored in the CMOS memory. Each time the system is booted this number is recomputed and checked against the stored value. If they do not match, an error message is generated to tell you that the CMOS memory contents may have been corrupted and therefore some settings may be wrong. BIOSes react in different ways to encountering this sort of error. Some will warn the user and then continue on with whatever settings were in the CMOS. Others will assume that the settings that were in the CMOS were corrupted and will load default values stored in the BIOS chip "for safety reasons". The error message will indicate which your system is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that is losing power. Viruses can also affect CMOS settings, and motherboard problems can also affect the stored values.
Recommendation: Follow the instructions in this section to address the CMOS corruption. You should make sure that all of the BIOS settings in the system are correct, by rebooting the system, going into BIOS setup and double-checking all the values (hopefully against a recent BIOS settings backup).
Sep 24, 2010 | Computers & Internet
Ref GA-81PE1000L Error message on boot up
all the computer bios settings are stored even when the computer is off (like time and fsb)
these are stored due to the help of a cmos battery
when this battery finishes it gives the CMOS Checksum error Default loaded error
all you need to do is replace the cmos cell
it is a mercury cell (looks like a silver coin) and will be placed on your motherboard
it is very very cheap so go buy one and replace it and be happy
Sep 30, 2009 | Intel Motherboard
Boots to 'CMOSS checksum error'
Explanation: A checksum is computed as an error-detecting code, to protect the BIOSsettings stored in the CMOS memory.Each time the system is booted this number is recomputed and checked against the storedvalue. If they do not match, an error message is generated to tell you that the CMOSmemory contents may have been corrupted and therefore some settings may be wrong. BIOSesreact in different ways to encountering this sort of error. Some will warn the user andthen continue on with whatever settings were in the CMOS. Others will assume that thesettings that were in the CMOS were corrupted and will load default values stored in theBIOS chip "for safety reasons". The error message will indicate which yoursystem is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that islosing power. Viruses can also affect CMOS settings, and motherboard problems can alsoaffect the stored values.
You should make sure that all of theBIOS settings in the system are correct, by rebooting the system, going into BIOS setupand double-checking all the values (hopefully against a recent BIOS settings backup).
If you have created a backupcopy of your CMOS settings then use them to restore the settings to the correctvalues. To find the problem itself:
Apr 06, 2009 | Intel Motherboard
CMOS Error
Are the CMOS batteries good?
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
CMOS checksum error
rahul23petit
"CMOS" checksum error default loaded" means ur mother board cmos battery fail (which is locate at mother board), to solve this problem replace it by new one (u can buy it form any computer accessories shop). all oher problem happen for it.
Jul 06, 2008 | EliteGroup BKi810 Motherboard
CMOS Error
Jan 24, 2008 | Mercury P4VM800M7 Motherboard
MSI KM4M-V Motherboard Logo
1,897 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
