Question about Neff 24 in. S5543X2 Built-in Dishwasher
Water build up in dishwasher- clogged drain
Can I use liquid plumer or something like that to clear a clogged drain in my dishwasher? The sink that it is hooked up to doesn't seem to be stopping up, but there is water left at the bottom of my dishwasher after washing. The clog must be between the dishwasher and the pipe it is hooked up to.
  • Anonymous Mar 21, 2014
    There are lots of very hard chunks of build up clogging the drain screen and keeping the water from completely draining
    Scholar:
  • 121 Answers
I would not recomment putting chemicals in the dishwasher. There is usually some kind of filter in the bottomt at you can easily take out and clean. It's common to have parts of labels and plastic clog this up.
Try removing and cleaning this first. It may also be reached from a separate hatch in the fronc of your dishwasher, depending on the make and model. Just make sure it's securly back in place before you start it afterwards, or you may flood your kitchen.
You may also try to disconnect the hose and blow through it to see if you may be able to blow back any objects stuck there.
If none of this helps your problem may be in the pump, and then it's usually a job for professionals.
Posted on Nov 07, 2007
Sink backed up went in dishwasher. Then it drain in sink. Fixed sink stopped up but washer keeps draining but nothing in drain
Your post is a little confusing but I'll try my best.
First, it sounds like you fixed the sink problem and now have a dishwasher problem related to the backup.
I would take the drain line off both the sink and the dishwasher and clear anything that got stuck in there while fixing the main sink drain. It could have had something plugged into it by using a plunger on the sink.
If you have any standing water in the dishwasher, pushing the cancel button should activate the water pump and you should see the water drain into the insinkerator, etc whilst hearing the pump. If you hear the pump and see no water draining but still have water in the dishwasher, you have a clogged line. If you don't hear the pump, your pump might not be working or the cancel does not activate the pump.
Jan 17, 2018 | Dishwashers
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Dish washer water is clogged up
sounds like the pump is running but clogged. You might want to 1-remove as much water as possible by cupping it out manually,2- turn the breaker off and ensure no power, 3- take off bottom cover, 4-locate drain line (it will go into cabinet under kitchen sink-hooked up to sink line more than likely) and take off pump on dishwasher end and take off sink. you can remove the hose and see if and where clog is located.Grease is sometimes a culprit or other bits and pieces of food build up. You should also investigate the area where the drain line hooks into the unit and ensure that is clear. reconnect hose under sink and fish thru hole in side of cabinet to back of dishwasher. someone else or you can then reach under dishwasher to reconnect line to dishwasher. make sure drain is hose is connected properly at both ends! You'll probably need a phillips head screwdriver, 1/4" nutdriver and a pair of pliers
Jan 15, 2013 | Dishwashers
My dishwasher isn't draining. The garbage disposal is hooked up separately.
Is sink drain line clogged?
Disconnect drain line at sink tailpiece and lower down to see if water inside dishwasher drains.
Call serviceman to clear clog in dishwasher hose, or repair dishwasher pump motor.
Oct 13, 2012 | Whirlpool Gold Dishwasher with Quiet...
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
When my dishwasher drains both sides of sink fill with water...then they both eventually drain back into the dishwasher.
Sounds like your sink drain trap or line is clogged. When the dishwasher drains, the sink drain can't keep up, the water backs up, then backs down the dishwasher drain line into the dishwasher. You may not notice the slow line when you run a little water into the sink, but with the amount of water coming from the dishwasher the problem is worse. You can try taking off the trap under the sink and making sure it's clear. If the problem is farther down the drain line, you can try snaking it yourself, or call a plumber. I don't recommend using Liquid Plumr or Drano because if those don't work, they leave the line full of caustic chemicals for the next person who works on it. That can be dangeerous.
Dec 07, 2010 | Microwave Ovens
Does not want to drain. If I push the
1st i would remove the hose that goes from the dishwasher to the sink.(the drain hose) hooks up to your disposer or your plumbing under sink. remove that hose and clean out both ends could be something clogged their. i see that every day. if both ends r clear then id say your pump is bad or your pump is clogged up.hope this helps
Oct 07, 2009 | Whirlpool Dishwashers
Sounds like it's running but no water seems to be getting to it
Your drain m ay be clear but it sounds as though the dishwasher line may now be clogged, remove the dishwasher drain line from the trap below the sink and check for leaks. You drain nthe dishwasher into a bucket.
Mar 20, 2009 | Dishwashers
Water drains thru the vent
If water flows from the vent, it indicates some type of blockage in the drain line downstream of that point. You can rent something called a "Drain Snake", which will require you to take apart the drain line to clear the obstruction, or you make purchase some liquid drain cleaner and see if that will clear the problem.
Hope this helps,
Kermit
Aug 23, 2008 | Magic Chef 24 in. DU2000 Built-in...
Neff 24 in. S5543X2 Built-in Dishwasher Logo
1,273 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
