Question about Belkin Computers & Internet
I have a belkin g router and i have mckafee virus protect i think that other people on using my internet. I saw several ip addresses linked to my network
    Problem Solver:
  • 18 Answers
Are you able to set your modem into bridge mode and set up a broadband connection??? That should in fact be a alternetive solution for your wireless internet connectivity, or. Try setting your WEP within the router settings using the 64bit key with any 10digit number to protect your wireless connectivity.
Posted on Jun 29, 2009
What Is the Default IP Address of Belkin Router? And determine Admin password?
HI ! HERE YOU GO!
https://www.lifewire.com/what-is-the-default-ip-address-of-a-belkin-router-818062
How to Find the Default IP Address of Belkin Router
Oct 24, 2017 | Belkin Computers & Internet
Hii there I have bought a Belkin wireless Router G F5D7234-4-H V5. Im from Bangladesh and using windows 7 professional as OS. Several times I have tried to setup using the web browser format which was...
Make sure the you are wired correctly. 1) The incoming cable/dsl to the modem. 2) The modem to the WAN (Internet) RJ 45 connection on the router. 3) The router wired to the computer during set up. You can not set up the router unless you are hard wired to the router.
Then try connecting using the IP address Belkin sent you. Probably 192.168.1.1 or 192.168.0.1. Use Internet Explorer.
May 16, 2011 | Belkin (F5D8231-4) Wireless Router...
I have a belkin g+ mimo router and am currently trying to set it up as an access point to interact with my d-link dir-615 router. when i add my d-link routers ip address string, the belkin disappears. i...
Hello...
Steps To Convert your Belkin Router as an Access Point.
- Connect your D - Link Router to your PC & Check the Default Gateway It Might Be 192.168.1.1 or 192.168.0.1
( Finding Default Gateway: Right Click on Local Area Connection & click on Status - Click on Details For Win 7 & Win Vista & For Win Xp - Right Click on Local Area Connection & Click on Status, Select Support Tab & Click on Details )
- Now Connect the Belkin router to your Com .. Open Internet Browser & Go to 192.168.2.1
- Towards your Left Corner Under Wireless Clink on Use as Access Point
- It will Prompt you For a Password Leave it Blank & Click on Submit
- Select the Radio Button Next to Enable
- In Specify IP Address Type in IP Address in Range of your D - Link Router Eg: 192.168.0.254
- Select Subnet Mask - 255.255.255.0
- Click on Apply Changes
- Now Open the Router Setup Page Using the Ip Address which you gave EG: 192.168.0.254
- Connect an Ethernet cable From your D - Link Router to Any 1 of the Wired Slots on the Router ( Note: We are using Wired Slot as we have Disabled the NAT on the Belkin Router It Gives you IP Address From your D - Link Router & the DHCP on the Belkin Router is Turned Off)
- Power cycle the D- Link Router & Belkin Router For 15 Seconds Each ( Unplug the Power cable & Plug it Back After 15 Seconds)
- Now go to the Router Setup Page & Check the Internet Status in the Top Right Corner It Would Be Connected.
- Try Going Online... :)
Feb 19, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin wired voip iad not connecting to internet with macbook
Try opening the Network Control Panel on the MacBook. Select the TCP/IP tab, then click Advanced. Note the list of IP address numbers. Click the "Renew DHCP Lease" button and see what changed. Most likely all of them did, in particular the "Internet Gateway" and "DNS server" addresses. The first is the connection between the D-Link router and your ISP, and the other addresses are for servers that translate your web browser URLs into the IP addresses for the web sites you want to see. The Gateway and DNS server addresses have to match those in the upstream router(s). The routers must have current IP addresses assigned by the routers upstream, and any client computer must have a current address assigned by the first route upstream. You can check into this by logging in to the webpages for your routers and examining the status reports.
Apparently one of the devices in the chain fails to obtain a new IP address when the D-Link router is powered on. I suspect it is the Belkin router. A computer with an expired DHCP lease will probably be using the Internet gateway IP address assigned to the D-Link router when it was on before (in a busy neighborhood, that address would have been re-assigned to some other household). The Windows system may be sending a request for DHCP renewal up the line, which triggers the Belkin router to ask for the same from the D-Link unit, but it may be ignoring the signal from the MacBook or not getting one.
If the MacBook successfully gets online with a manual Renew DHCP Lease request, obtain the owner's manual for your Belkin router (find the model number, then go to the Belkin support/downloads page for that model). See what settings are available to automate the DHCP renewal process.
Jul 10, 2017 | Belkin Computers & Internet
Belkin Wireless N router/Embarq 660 modem/No internet
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Apr 15, 2009 | Belkin (F5D8231-4) Wireless Router...
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
Program for belkin router
you don't require the disk...
co0nnect your belkin router with ethernet cable into the comp...
open internet explorer type an address as 192.168.2.1 it will take you to router config page..it will ask for a password leave it blank
click submit
click the Wizard link on the top menu bar.
For a UK ADSL connection, you will need to select PPPoA (Routing mode, for multiple PCs) even if you are only going to connect a single computer, then click the next button.
The next step is to enter your username and password that your service provider has provided you with. To try and ensure the password is entered correctly it must be entered twice. The VPI/VCI values of 0/38 are the correct ones for a BT Wholesale ADSL line. If you are using another telephone provider check the settings required. Click next again to continue to the next phase in the wizard.
This screen tells you what your Internet IP address is (the WAN IP), and you will note that the menu bar at the top of the page now shows the Internet Status as connected. For the review, there is really one bit of configuration left to do. During the course of reviewing hardware we tend to swap kit in and out several times, we generally prefer to run the routers on the same IP address (192.168.0.1). This is easily accomplished by clicking the LAN Settings link on the left hand menu of the Belkins web setup and altering the routers IP address.
The router is clever enough to alter the DHCP server IP ranges to match the new LAN IP address of the router. Once the changes were applied it took around a minute for the router to restart, during which time the wireless signal dropped, but once this reconnected the PC was assigned an IP address in the new range of 192.168.0.x.
Feb 16, 2008 | Belkin (F5D7000) 802.11g/b Wireless...
IP address
Hi tammyhope,
I would guess that your ISP is providing a dynamic IP address for connectivity to the internet. If your router is changing the IP address back to default, I would think that your configuration is not setup properly, to receive a dynamic address, but is set with a static address instead. So what happens is that when you attempt to connect to your ISP your router is resetting. If this is the case then you need to go into the router configuration and set it to recieve a dynamic address from your ISP.
--RoadHawk
Nov 25, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
67 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
