Question about iRobot Roomba Discovery SE Bagless Robotic Vacuum
It won't keep a charge and it doesn't do anything but beep when I push the buttons to spot, clean and max.
  • 75 Answers
What kind of vacuum is it.
Posted on Jun 29, 2009
I have a dyson V6 Mot?rhead model Ju4-us-GBR7075 My machine when I push the power button the machine stops and goes
Hello, this is Ava with Think Crucial.
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it can be due to a battery of the cleaner. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 21, 2017 | Dyson V6 Motor Head Cordless Vacuum
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    What are these 2 blinking lights on my irobot roomba?
    "The Charge Indicator Light is located immediately to the right of the power button on Roomba Red and Roomba (sage). On Roomba Discovery and Discovery SE, the Charge Indicator Light is incorporated into the power button. Please refer to the table below to determine what the Charge Indicator Light is telling you.
    * Pulsing Amber - Charging
    * Green - Fully Charged
    * Amber - Partially Discharged
    * Red - Almost Fully Discharged
    * Flashing Red - Fully Discharged"
    At the end of a cleaning mission, Roomba will tell you if it has successfully completed it's mission or not:
    GREEN = MISSION COMPLETE
    YELLOW = MISSION ABANDONED (Check robot's brushes, etc.)
    YELLOW RED POWER BUTTON = BATTERY DEPLETED (Scheduler Models)
    RED YELLOW POWER BUTTON = BATTERY DEPLETED (Discovery Models)
    number of beeps after ?uh-oh? :
    No beeps: A wheel is stuck or is not touching the ground. Pick up the robot, place it down securely on the floor and touch the clean button to restart the cycle.
    1 beep: The main brushes cannot turn. Turn over Roomba and remove the brush guard by pushing the two yellow tabs. Remove the brushes, clear any obstructions, and replace them again.
    2 beeps: The side brush cannot turn. Turn over Roomba. Look to see if something is wrapped around the side brush. Remove the side brush with a screw driver and check for string or hair that may be wrapped around it.
    3 beeps: The vacuum cannot run Remove and empty Roomba?s bin.
    4 beeps: A wheel motor cannot run Your Roomba may be stuck or something may be wrapped around a wheel. Look for something wrapped around the wheels. Push them in and out and make sure they turn easily.
    5 beeps: The cliff sensors have failed or are blocked. Turn over Roomba and clear any debris that might be caught underneath the front bumper in the cliff sensors. You can also use compressed air to clean them out.
    6 beeps: Wheel obstruction or robot attempting to drive over an obstacle. Turn over Roomba and remove any obstructions that prevent the wheels from seating all the way up into Roomba?s body. Also, remove any obstacles that Roomba could drive over.
    7 or 8 beeps: Not applicable Roomba?s beep codes do not include 7 or 8 beeps. If you are getting an error with 7 or 8 beeps, try counting again or contact iRobot Customer Care.
    9 beeps: Sensor error Please contact iRobot Customer Care.
    10 beeps: Roomba is stuck Pick up Roomba and start it again somewhere else. Use a virtual wall or other barrier to keep Roomba away from the
    place it got stuck.
    Your Roomba may be experiencing an issue where the battery is deeply discharged and may need to charge longer than the standard 3 hours. (or 7 hours if you have a standard charger)
    Even with the charging light showing green (this indicates a fully charged battery) the robot is still charging. If your Roomba exhibits behavior where it charges for a short time then runs for a short time you will need to do the following.
    1. Plug the charger into Roomba (if you have a home base be sure to plug directly into Roomba instead of using the home base, this will ensure the robot's charging cycle is not interrupted.)
    2. After the Roomba's charging indicator goes to solid green please keep the Roomba on the charger for an additional 72 hours. (3 days)
    3. After the 72 hours (3 days) has passed, turn your Roomba on and begin a normal cleaning cycle. If this works successfully it may take several uses for the battery to get back up to the performance it once had.
    If this does not correct the problem, please call customer support at 877-855-8593
    Nov 22, 2012 | Vacuums
    My roomba 530 cleans just great, but it will not return to the docking station--it just stops in the middle of the floor without any warning. I push the dock button, etc. to no avail.
    I sometimes have the same problem with my Roomba 530 (named Ethel). Make sure the signal transmittor on the docking station and the signal receiver on the top of the Roomba are clean. You can use a cloth or paper towel with a SMALL amount of window cleaner to run around both of these signal devices. I also like to clean the metal contacts on the station and the corresponding contacts on the bottom of the Roomba at the same time. This won't make a difference for the docking but it just assures that the vacuum will charge efficiently. If this doesn't work, you might need to have the unit cleaned professionally unless you feel comfortable about taking the unit apart and cleaning it yourself. I did this and Ethel has worked fine ever since!
    If this helps, please come back and rate my suggestion!
    Jun 06, 2011 | iRobot Roomba 530 Robotic Vacuum
    My roomba stays in one spot and cirles like it's spot cleaning and it's not. It won't move around like it use to,i haven't used it in some time altho it is charged.
    You need to clean the sensors.....you have pets...the dander gets on the sensors...it's a common issue. (See...you didnt even tell me you had pets!)
    Mar 22, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
    My roomba mounts up to the charger the light blinks red then after a time it goes green but when I dismount it and push the green button it immediately goes red. It doesn't beep or do anything. It is that...
    You have dead nimh (nickle metal hydride) batteries. You will need a replacement. You can test for this by removing the battery and holding the power button for 15 seconds. This will restart the charging cycle as if the battery were new.
    Feb 07, 2010 | iRobot Roomba 560 Robotic Vacuum
    My roomba discovery will not operate on the clean or max buttons, will do the spot clean and goes forward then circles. Turns itself off and plays a little da do da do do do do. I have emptied tray,...
    If your Roomba goes "uh-oh", beep-beep-beep, that's a 3-beep error code, indicating that your vacuum motor is stalled. Remove the grill from the outside (back) of the dustbin and make sure that the impeller (looks like a fan) turns easily and is not clogged with dirt. Then try to run the robot with the bin ON but the grill OFF. You should be able to tell whether the vacuum impeller is spinning. If not, you'll need a new bin. You can confirm wth customer support by calling 1-877-855-8593.
    Jul 16, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
    Powers on but will not run, goes BONK when button is pressed.
    OK, I have fixed my Roomba!! First I went out and searched the web for Troubleshooting info. What I found was the diagnostics that the factory uses to test them. So going through the diags. I found that 3 of the 4 IR Sensors along the front were not working. So I took the Top Cover off, then removed the Sensors from the front Bumper. I found a red wire that had been cut from the drop. Repaired the wire and all is good !!!!
    Jan 02, 2009 | Roomba Robotic Floor Bagless Vacuum
    iRobot Roomba Discovery SE Bagless Robotic Vacuum Logo
    437 people viewed this question
    Top iRobot Vacuums Experts
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
