Question about RCA D52W19 52" Rear Projection Television
Tv takes forever before powering on - RCA D52W19 52" Rear Projection Television
I have a Samsung hlr6156wx/xaa 61 inch tv and the TV takes forever to turn on.
There are many capacitors on the power supply board that need to be replaced. You can get a parts kit or a complete replacement board to fix it. Get the parts from:
TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 08, 2015 | Samsung Televison & Video
Hello my 2004 Hitachi Ultravision rear projection tv takes forever to get picture and sound after I turn it on. What should I do?
Capacitors on the main and power board are most likely bad. If your feeling adventurous you could try replacing them, or buy a new TV.
Dec 29, 2014 | Televison & Video
TV clicks on and off on and off on and off it takes forever to come on. can this be fixed
STOP TURNING ON YOUR TV YOU WILL MACK THINGS WORST THE ARE BILGED OR WEAK CAPACITERS IN YOUR POWER SUPPLY OR A PCB THATS SHORT
Nov 17, 2010 | Samsung LN52B630 52 in. LCD HDTV
Tevion tv 42 LCD 4203 Having problems turning on takes forever for screen to come up 10-15 mins on average
You have bad caps on the power board, you will have to take the back cover off and have a look on the power board, if you see any leaking caps or the tops have a dome shape or bulging they will need to be changed.
Feb 17, 2010 | Televison & Video
Tv takes forever to come on
tienes un problema de soldadura fria en el tv en general
Aug 28, 2009 | Televison & Video
When turning on tv takes forever and then red lights flash on sid
Sounds like your lamp is blown . Replacement part is UX21516 lamp. this is a common problem with my 50VG825 also, 3 lamps in less than 3 years. Try this if you have'nt already. Hope I helped
B.Crowell
Mar 04, 2009 | Hitachi 50VG825 50 in. LCD HDTV
TV takes forever to come on and then very dark
IM Afraid unit required to be serviced , problem at the inverter transformer or faulty capacitors at the POWER SUPPLY unit , hope this helps AJ
May 25, 2008 | Samsung SlimFit TX-S2783 TV
RCA D52W19 52" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
