Question about Nintendo Wii Console
I have a green light but no picture on tv tried unplugging it also tried hooking it up to another tv no luck
    Novelist:
  • 166 Answers
Try bending the a/v cable in spots.if a picture start to come through then it is your av cable.if it is your av cable you can fix the existing one or buy a new.if you want to know to fix the av cable email me gamecrazy944@yahoo.com
Posted on Jun 29, 2009
My Samsung DVD TV 15G10 is 3 years old and has functioned perfectly until the other day when I turned it on to view and since have had only sound and no picture. Grateful for any thoughts on how to...
firstly i dont know how the video is hooked up to tv - so if what i recommend doesnt work i would suggest giving more details
if video is hooked up to tv through component video (red, green, blue wires) try checking the green wire- if green wire is bad you will get no video on your screen you can try using one of the other wires to test if you dont have a new component video wire to try
secondly if that doesnt work try hooking the source up to a different input on tv and see if that works
next i would try another source for your video to be hooked up to tv ( maybe a dvd player or something like that)
if all of those tries dont work you might either have had the bulb for the back light go bad ( backlight bulb is usually a flourescent light bulb and it makes the screen get bright so you can see it) or the power supply for either the backlight bulb or the video high voltage go bad in which case i would recommend bringing in for service or just buying a new replacement (they are fairly cheap to buy new now so it might be a better alternative to a repair)
sometimes you can tell if it is backlight problem by making room very dark and look carefully at screen to see if you can see a picture on it - if you see a faint picture on screen then it is definately your backlight that went out
if you need more help write back with as many details you can give me about what wires you have connected things to tv with and what sources you have connected to tv also
good luck!
Mar 25, 2011 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
I have no picture at all. The green light on the
Unplug the tv and run a fan on it for at least an hour, plug the tv back in. This is the free solution, otherwise repari or replace the tv. Be sure to make sure other items don't work as well. Test a dvd player or another device against the TV. Try hitting other buttons for other inputs on the TV to see if the TV responds.
Good luck :)
Aug 25, 2009 | Sharp Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green blnking light on pioneer plasma - Picture does not come on
You can try a hard reset : Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
Nov 23, 2008 | Pioneer PureVision PDP-5030HD 50 in....
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
Nintendo Wii Console Logo
111 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
