Question about Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum
My Bosch 1450 Bagless Jet vacuum cleaner shuts off
Same problem as described here.
There seem to be a pattern though. It does it most of the during the summer when it is hot outside, hence warmer inside.
Wondering if this is because I have not changed the filters for a while?
  • 75 Answers
Maybe or it could possibly an eletrical problem.
Posted on Jun 29, 2009
The cylinder of my Electrolux upright vacuum cleaner is jammed tight onto the casing and I cannot remove it for cleaning ( plastic to plastic) what is the best way to remove ? Tried getting hot water in...
Ah.
Hot water on the outside, not on the inside :)
The idea is to warm up the outside and keep the inside cool.
Try wrapping the inner casing up in some corrugated cardboard to keep it cool and gently using a hairdryer on the outside part that's jammed on, until it's hand-hot. This should expand it ad, maybe soften it, sufficiently to remove.
Jan 31, 2015 | Electrolux Vacuums
My bosch 1450 vacuum does not have suction
Have you changed the bag lately? If not, I would try that first. If so, then check to be sure that nothing is blocking the pathway of the suction area. Check those two things and if you still have problems, come back and let us know.
Sep 16, 2014 | Bosch Turbo Jet Bagged Upright Vacuum
Helpline. Ive been given a rollerball dyson by a friend who doesnt use it anymore. I have cleaned the filters but as it has been used where there have been animals I find a very bad smell of dog from the...
easy fix, just stip the cyclone down into 3 peices. the innercores can get caked with grime hence the doggy smell.
if you have a dishwasher then use that if not soak in hot water with some bleach overnight
Aug 22, 2017 | Dyson Vacuums
Vacuum cleaner stops
The motor has a thermal reset built in. If the filters need replaced the motor can overheat. Filters should be replaced frequently to insure proper cleaning suction and motor life
Jan 04, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Trigger switch cuts off during use
make sure the filter is washed thoroughly. I have/had the same problem and washing the filter helps a lot - it cuts off if overheating....and avoid picking up really fine dust like after drilling picture hook holes...
Feb 02, 2013 | Dyson DC34 Bagless Cordless Hand Vac -...
Ball filter is popping up, stopping ball rotating and ball area is getting hot
I'm sorry to hear you're having difficulties with your DC25 Animal. If the filter inside the Ball will not stay in place during use, please make sure that when you refit it, it locks into place with an audible 'click'.
I can confirm it's normal for your Dyson to become warm during use, but if you're concerned that it seems excessively hot, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 16, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
Filter mesh holder is damaged, locking holes are broken will not lock in place - need new filter mesh
Hi Joe: The model has been discontinued and difficult to find replacement parts. I located a few online suppliers offering a HEPA Filter that fits the BUC11700UC. See here:
http://www.vacuumcleaners.net/bosch-buz200hcuc-hepa-filter-for-bagless-jet-upright.html or
http://www.allergybegone.com/boshepfilfor4.html or
http://www.wikio.com/product/vacuum-parts-accessories-compatible_with_bosch-reviews-12020-page3-sort0.html
Is this the part you are looking for? The third site above does offer other replacement parts if you are looking for a different filter piece.
Thank you for using Fixya!
Jan 14, 2012 | Bosch BUC11700UC Cyclone Jet Bagless...
Bionaire humidifier model:bcm7309cm How to clean the air filters?
"You should change your furnace filter once a month in the winter season and your central air filter once a month during summer months.
If you run your heat or air every day and night, have pets, or your home collects a large amount of dust, you may need to change your filter more often during very hot and very cold months.
If you use disposable filters, it's really not worth vacuuming them to reuse them. They are inexpensive enough that you should replace them instead.
Disposable filters don't work as well after only being vacuumed and they are usually in a cardboard frame and therefore don't wash well.
Before you take out the filter, however, vacuum the outside and around the filter encasement. After you remove the filter, you should vacuum behind it, too, to catch any stray dust and particles.
Replace disposable filters with new ones."
(http://www.mrscleanusa.com/en/cleaning-tips/tip/cleaning-air-filters.html)
Mar 03, 2011 | Vacuums
My mach 5 vhoover vacuum cleaner shuts itself off alsomst as though it is overheated
No your motor is going bad. Have you ever owned an electric fan. If you can remember when the motor started going bad on it the fan would quit turning on its own.Your vacuum is doing the same thing. Please call Hoover and order a new one or go to ebay type in the make and model..
Aug 27, 2010 | Hoover U5194-900 Mach5 Multi-Chamber...
Bosch BUC11700UC Cyclone Jet Bagless Upright Vacuum Logo
425 people viewed this question
Top Bosch Vacuums Experts
Billy Detlefsen
ray gallant
JoeVacs
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
