Question about Ruud UAKA060 Air Conditioner
I have an old Ruud(ac/heater)top house. Maybe 20 years old. the fan extracting hot air from coils sometimes stops working and the unit does not cool. I called a local repair man and he changed a small module of some sort. he said it was the problem. two weeks later the samething. I believe he's an idiot and im relectant in calling another repairman. I went up and with a small screwdriver i gave the fan a little push and it began to work. Can the fan motor be the problem?
    Genius:
  • 1,689 Answers
Agree, this clearly is a fan motor problem when pushing it made it run.
Most fans that have the same issue may need bushing / bearing replacement. and if that did not resolve the issue, then a recoil will surely put the rotating power back on the motor.
in this link, check out the figure
the bushings may look like this
I have an old Ruud(ac/heater)top - a3c162a.jpg
or these
or even these,
there are different types of bushings for every fan but have the same purpose, which is make sure the motor rotates in balance.
recoiling helps the motor become more powerful because of the fresh copper coiled wires conducting more electromagnetic charge.
hope this helps.
regards,
voodoo
Posted on Jun 29, 2009
Hello all My Rudd AC unit will start and run find maybe for 10 minutes and cool air then the fan outside will stop and unit hums or hisses and blows hot air inside vents. I changed out Thermostat and Run...
Welcome to the world of Ruud! Ok James heres the deal. It sounds like the condenser fan motor has failed. Its not a repairable item but the motor is not too expensive. Disconnect the main power at the fuse block on the side of your house next to your a/c. Remove the screws that hold the top fan section and carefully turn the fan/panel assembly over taking care not to stress the wires. Determine how the fan is mounted (probably 4 screws) and go find your new motor. Both Rheem and Ruud use the same motor mounting. Most a/c supply houses have a motor that will fit or go to graingers. Make sure you get a matching run capacitor for that motor. It will have separate wires and not share any wiring with the old capacitor. The old capacitor will have to stay in place since it is also connected to the compressor. The old motor will have 3 wires and the new one 4 (2 brown for the capacitor and 2 others to put on the contactor that the compressor wires go to). If its a heat pump it could be a board and youll need help. good luck
Aug 15, 2013 | Ruud UBHC Air Conditioner
I have a digital Honeywell thermostat that has a blinking snowflake. When the thermostat is on auto mode it does not turn on. When I turn the thermostat to fan I can feel and hear the air blowing out of...
If the thermostat has a blinking snowflake then it is in time delay mode which sometime can take between 5 to 7 minutes before it will turn the AC and Fan On......Then it will go to a solid snowflake.
When you turned it to fan On it starts the Fan right away..... After the snow flake has went to solid check to see if the fan is running and then look outside to see if the Fan Blade is turning on the AC..... The fan blade comes on the same time as the compressor does. Then with the fan running hold your hand above the air stream above the AC and if you can noticeablely feel warm to hot air comeing out the Top then the compressor is running also. If the outside unit is not running I would check to make sure the Main Breakers are turned ON.... After the AC has ran for a few minutes feel the copper lines that go into the house the smaller line should feel warm to hot and the bigger lines with insulation on it should feel cool to cold and sweating with beads of moisture on it..... That is a quick test to see if the unit is working properly.....If you have a Thermentor and can Check the Temperature of the Return Air and the Supply Air .. You should have about 20 Degree F Between the Supply and Return........ 75* Return - 55* Supply would Equal 20* TD Across the Coil......
That is about all you can do to check on your own....... If the compressor is not coming on or the lines are not the temperature difference then you will need to get professional help for your Air Conditioning System..... Goood Luck Hope this Helps.........
May 14, 2011 | Heating & Cooling
2.5 RUUD AC not working, power must be getting to the unit.
Have them turn the outdoor unit off and wait a few minutes. When they turn it back on they should here
the fan and the compressor come on. They are to different sounds.
If they think that they have both come on, tell them to check the black insulated suction line. it should at least cold to the touch. If not it could be a freon issue.
If the line does get cold, have them checkthe filter in the house. If that is ok tell them to turn the power off
to the outside unit. Take a garden hose and wash
the outside coils on the outdoor unit,be carefull not to
smash the fins. Wash them at an angle from top to bottom.
Jul 05, 2010 | Ruud Central System Air Conditioner
Fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Sep 14, 2009 | Ruud UBHC Air Conditioner
AC not cooling during the day
Your AC cooling efficiency is low when he ambient temperature is high and naturally it cools well when the outside temperature drops.
Please remove the filter on the grill and try to clean it under the tap water and after removing all the dust fix it back to the unit. This would increase the cooling efficiency of the unit.
Your AC is also five years old. Please avoid frequent opening of doors or windows.
Ensure that the exhaust fan and the blower of your unit are functioning normal.
The technician might not have done a proper job in fixing the area where the refrigerant would have leaked out. Please check the refrigerant pressure to ensure that no further refrigerant leak has taken place. Or even servicing your unit he would have punchered the tubes resulting in very slow leak of refrigerant resulting in no cooling or less cooling. It takes around a month to feel the pinch of it and the refrigerant. One fine morning after sometime the unit will run and it would start throwing hot air instead of cool breeze!
Jul 13, 2009 | Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
I have an old unit on a hot day it stops working
that pops when the internal pressure gets too high,try cleaning coils off with hose,could have a fan motor not running up to speed.
Jun 25, 2009 | Ruud UAMB Air Conditioner
Compressor will not start.
Usually short cycling means that High side pressure is getting to high (due to not working condenser fan, or dirty condenser coil), or low side pressure is getting too low (might have low level of freon or restriction in sealed system). low side would drop dramatically if indoor blower is not running, so if air is not circulating thru evaporator coil, coil will freeze up and low side would be much lower then normal. Here is video how I found issue with package AC not coming on. Thermostat call for cool, but condenser would not come on, indoor blower runs ok.
Nov 02, 2008 | Ruud UAMB Air Conditioner
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
Ruud UAKA060 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
