Question about Apple iPhone 3G
Same thing in 3.0
I have this error on a 1st gen iphone after upgrading to 3.0 and none of the below solutions worked for me. I tried them all. When I created another user account, I got the same error when trying to sync.
  • 30 Answers
This is a common problem, iPhone is working on it right now.
Posted on Jun 29, 2009
How to unlock my iphone1gen with no any cost for free
Hi, just follow these instructions carefully and you will be able to unlock your 1st gen iPhone for free.
1. Download firmwares 3.1.2 and 3.1.3 for iPhone 1st Gen. http://modmyi.com/wiki/index.php/IPhone_Firmware_Download_Links#3.1.2
2. Download bootloaders 3.9 and 4.6 http://www.iphone-hacks.com/iphone-downloads/file/109. Download Redsnow 0.9.2
3. Restore iPhone to 3.1.3 using iTunes
4. Press shift + restore then select 3.1.3 firmware
5. After restore, run Redsnow, select 3.1.2 firmware
6. Select "Install Cydia and Unlock"
7. Follow the instructions and don't unplug the phone for the whole process.
8. After the jailbreak is done, your phone will now be unlocked and jailbroken.
Mar 12, 2011 | Apple iPhone Smartphone
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
Is a 2g touchscreen compatible with a first gen Iphone? Will it work if I buy the part on my 1gen phone?
Do you mean a replacement glass to put on your 1st gen iPhone? It can get a bit confusing with the 'Generation' labelling, as 2G in fact refers to 1st Generation iPhones (any prior to the 3G, hence 2G - it relates to the data connection protocol more than the hardware version).
So, with that in mind - am I correct in assuming that you have seen a 2G screen for sale?
If so then yes it will work on your 1st Gen (2G) iPhone. I haven't compared the 2G/3G screens that closely, but I do know some of the sensors are located in a slightly different position on the 3G which may in itself be an issue.
Let me know if you want me to further investigate and I'll help if I can!
Oct 28, 2009 | Apple iPhone Smartphone
Poor sound quality via Bluetooth mic after switch to iPhone 3GS
Unfortunately, solution is NOT free. Until Apple decides to take good look into this issue, you are left to buying another BT headset model.
I got lucky first time around, bought new Plantronics (not Playtronics...) Voyager 520 (I do love Plantronics 3xx design, this is the next best thing). It did cost almost twice as much as my previous headsets (about 45 EUR), but it's still on the cheap "side" and (to my experience) also the best value.
Hope new headset also lasts almost whole week before needing recharge, like my "old ones". :)
Aug 26, 2009 | Apple iPhone 3G
I upgraded my iphone and not recognizing my sim card???
you need to talk to your carrier and get a new SIM card, it will not work w/o the appropriate card. I had the same issue when moving from a 1st gen to a 3Gs and ended up going to the store... )-; hope that helps.
Jul 08, 2009 | Apple iPhone Smartphone
I upgraded from 2.2.1 to 3.0 on my 1st gen and now don't work
When you made the upgrade from 2.2 to 3.0, it relocked your phone to AT&T. You'll have to unlock your iPhone again to get it to work.
Jun 27, 2009 | Apple iPhone Smartphone
Iphone keypad not working
First try a hard reset. Hold down the power and home button simultaneously for 10 seconds until the iPhone reboots.
If that doesn't work you need a new digitizer. If it's a 3G I would advise replacing the digitizer. If it's a 2G I would not advise replacing the digitizer b/c you would have to replace the LCD, Digitizer, and the Glass Panel and the cost would exceed $100.
You could also consider selling your iPhone AS IS for parts or repair on eBay, Craigslist, BuyMyTronics.com or I could make you an offer.
Hope this helps, Rate me please!
Jun 17, 2009 | Apple iPhone Smartphone
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
Iphone restoration error (1601)
I found a solution!
It worked for me and many others (who posted their gratitude on the original post).
Below are the instructions you have to follow. If you have disconnected your phone or shut your iTunes, don't worry. I did it. I even reinstalled iTunes a few times and shut down the computer as well.
Here it goes:
"The way to get over the 16xx errors while restoring on any firmware is this:
Once you get the error DONT DISCONNECT IPHONE OR CLOSE ITUNES. Which leaves us with only one option, rESTART Iphone. STEP BY STEP GUIDE FOR VERSION 2.0.1:
1). You get the error. (Ofcourse)
2). DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.
3). If the phone is still on, reboot/restart the phone. If its off then kick it out of DFU mode which is explained in the NEXT step.
4). Press and hold the power and home button for some time to kick the phone out of DFU mode.
5). Itunes will detect it again.
6). Now try to simple-restore it, that is click on the restore button on itunes while pressing the shift button of your keyboard. YOU WILL GET THE 16XX ERROR AGAIN IN 5 MINS !!!! but dont worry, everything is under control.
7). now your iPhone will have the picture of the iPhone cable on its screen. good.
(DONT TURN OFF ITUNES. DONT DISCONNECT IPHONE CABLE.)
8). NOW put the iPhone it in DFU mode. How? Firstly turn the phone off (it might try to start up on its own again but turn it off again). Once its off, Press and hold the power and home button for 10 seconds, then release the power button but keep the home button pressed for another 10-20 seconds till itunes recognizes your phone.
9). NOW restore the phone by selecting the pawned custom firmware that you created and you will NOT get the 16xx error.
ENJOY."
I got this solution from here:
http://www.modmyifone.com/forums/pwnage/281841-error-1601-help-please.html
Hope it works for all of you.
Cheers!
Phil from Brazil
Aug 21, 2008 | Apple iPhone Smartphone
Apple iPhone 3G Logo
51 people viewed this question
Top Apple Cell Phones Experts
David
Martin Murray
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
