Question about Dell PowerEdge 2950 (becwfk1_6) Server
E2111 SBE LOG Disable DIMM - Dell PowerEdge 2950 (becwfk1_6) Server
The E2111 should also indicate a number after the DIMM, this is the bank of the DIMM it believes to be bad. Depending on your support contract situation, and ability to bring down the machine, reseating the module after cleaning it a bit with some good old 'canned air' may do the trick. Otherwise a module replacement is in order which is typically covered by DELL if you are still under coverage.
Posted on Jul 20, 2009
  • 60 Answers
While it is most likely bad memory in the indicated slot, you should swap the memory with another stick. This will help you determine whether it is a bad memory stick or a bad memory slot, and sometimes simply reseating the memory can resolve connection-related issues. This will probably be asked of you by Dell support anyway. If this has an older BIOS (less than 2.0.0), then it may also be a BIOS issue rather than hardware. Several BIOS revisions have been released to address memory and error handling.
Posted on Apr 08, 2010
I have the same problem and I can confirm that it is not bad memory.
After swapping DIMM 5 which is was complaining about it then begun complaining about 7, then 1 then 3.
Replacing all these cured it for 10 minutes then it went back to DIMM 5.
I also updated the BIOS to verion 2.7.0
Currently looking for a firmware update.
Posted on Feb 21, 2012
  • mike Sep 16, 2012
    i have also the same problem with Poweredge R900, after replacing the memory the error still appearing and we swapped also with a working memory, the error still appears in the same slot. Any help will be very much appreciated.
    New Friend:
    Problem Solver:
  • 5 Answers
Lorinfew,
The E2111 SBE LOG Disable DIMM error is due to a repeated Single Bit dimm errors filling the memory logs. What you will need to do is go to the hardware log in the Drac (Ctrl-E prompt on startup or via OpenManage) once there then view the log for any errors identifying specific dimms. Note the errors and dimm locations and then clear the hardware log, via the Drac/BMC or OpenManage, and then reboot and see if another error comes up. If so then power down the server and swap the listed dimm with other matching dimm in the server. If the error moves to the new location it is a bad dimm, if the error remains at the same slot as before then it may be the motherboard slot.
Let me know what you find.
Posted on Sep 04, 2014
E2111 SBE LOG DISABLE -DIMM 3
Hi
Two most likely causes for this error are
First: the memory module, DIMM3 has worked its way loose and needs to be reseated firmly in its slot with both catches firmly engaged.
Second: The memory module DIMM 3 has become faulty and needs to replaced.
If reseating the DIMM doesn't work try swapping slots with a module of the same size in a different slot and see if the fault follows the module or goes away. If the fault follows the module, eg to DIMM 1, then it is most likely that the module is faulty.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 30, 2014 | Dell OptiPlex Computers & Internet
An Alcatel One touch needs a new Sim Tray put in?Need a repair shop in Brighton
Give this company a ring and check if they have a centre in Brigton.
ATTN:SBE ltd
Unit A2
Beaver Business Park
Ashford
TN23 7SH
Client Enquiry: 0871-2000995
01233 619 320
Sep 21, 2014 | Cell Phones
How to open Insignia Model:NS-E2111 speaker not working
remove front cover and unlach bottom to get accses to speakers .
Sep 04, 2014 | Insignia Set Of 4 Indoor/outdoor Speakers,...
Metabo SBE 750 Have continuity through the trigger
IF you have continuity through the switch and the brushes look good then remove on brush and look at the commutator segments. There should be nice even gaps between each segment. If you have on that a goodbit wider than the others then your rotor is bad. If not then more than likley your stator is bad.
Aug 06, 2011 | Metabo Drills
HOW TO ENABLE 289 DIMM D01 is disabled in server 2008.
terrible question; please add more detail
if your system has a dual CPU socket, perhaps you don't have a second cpu (where more memory banks usually require that second cpu socket to be populated in order to use the dimm slots); doubtful, but there could also be a jumper on your mobo
or maybe look in your BIOS; that's where things are enabled/disabled (i.e. server 2008, afik, doesn't have a way to specifically disable a dimm slot)
the mobo (or system) manual may have guidance for memory installation; e.g. sometimes there's a size or slot population type table (or compatibility; i.e. maybe the memory you are installing is dual rank and the system only takes single, thus it appears that the slot is disabled)
Jan 11, 2011 | IBM eServer xSeries 3200 (43635FU)
Error 53.21 hp color 5550
Doesn't specifically mention the 53.21 error this is the closest they come so you will know it deals with the ram anyway
Control panel message Event
log error
message
Description Recommended action
53.XY.ZZ CHECK RAM
DIMM SLOT X
To continue press
CANCEL JOB
None An error occurred on some
memory of the printer.
X DIMM Type
1 RAM
Y Device Location
1 DIMM Slot 1
2 DIMM Slot 2
3 DIMM Slot 3
4 DIMM Slot 4
ZZ Error Number
0 unsupported memory
1 unrecognized memory
2 unsupported memory size
3 failed RAM test
4 exceeded maximum RAM size
5 invalid DIMM speed
Press CANCEL JOB. If the problem
persists, replace the DIMM card in
the slot indicated.
Click Here for Memory
hope this helps and if so please mark FixYa!!
Jul 30, 2010 | Office Equipment & Supplies
Please guide me the steps to disable the" print the event log"
If you don't want see a printer notification event in the event log you can disable that..
Start regedit and find the key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Providers".
Add "Eventlog" and set the value "Reg_DWORD" at "0".
google_protectAndRun("render_ads.js::google_render_ad", google_handleError, google_render_ad);
Jun 25, 2009 | HP LaserJet 1020 Printer
Please guide me the steps to disable the"print the event log"
You will need to edit the registry to do this.
Jun 24, 2009 | HP LaserJet 1020 Printer
E2111 SBE log disable DIM2
replace system memory, that indicates on lcd screen #dimm...#. In this case, dimm2.
Mar 05, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
I can not find sound device
JNEAVAT GUVF FVGR PBAGNVAF NQHYG PBAGRAG!
Guvf fvgr pbagnvaf zngrevny juvpu vf nqhyg va angher naq vagraqrq fgevpgyl sbe zngher nqhygf. Nyy frk fgbevrf ba guvf jrofvgr ner svpgvbany frkhny snagnfvrf naq ner choyvfurq urer sbe nqhyg ragregnvazrag naq negvfgvp rkcerffvba bayl! Vs lbh ner abg bs yrtny ntr gb ivrj nqhyg zngrevny va lbhe nern be lbh svaq cbeabtencul be nal bgure glcr bs frkhny zngrevny bowrpgvbanoyr be bofprar cyrnfr yrnir be pybfr lbhe jro oebjfre abj. Frk Fgbevrf Cbfg jrofvgr naq vgf bjare(f) pna abg naq jvyy abg or uryq erfcbafvoyr sbe nal pbagrag choyvfurq ba guvf jrofvgr. Vs Lbh cebprrq shegure lbh npprcg shyy erfcbafvovyvgl sbe lbhe npgvbaf naq pbafrag gb ivrjvat nqhyg zngrevny. Obbxznexvat be pyvpxvat orlbaq guvf cntr zrnaf lbh shyyl haqrefgnaq naq npprcg gur pbaqvgvbaf urer.
Jul 11, 2008 | ASUS P4SGX-MX Motherboard
Dell PowerEdge 2950 (becwfk1_6) Server Logo
34,462 people viewed this question
Alun Cox
