Water doesn't shut off causing overfilling of the
Washer is overfilling even when the water level switch is in low load position.Please advise.
    Sniper:
  • 68 Answers
The pressure hose may have come off the water level switch. you need to acess the control panel, check the water level switch, there is a small pressure hose that slides on the small stem toward the lower rear of the wl switch. if the hose is disconnected, put it back on & it should work fine. if the hose did not come off, you either have a bad wl switch, or the pressure hose is plugged and needs cleared. hope this solves your problem. shane
Posted on Jun 29, 2009
The washer is having the following issues. Overfills excess water drains out on the floor down the overfill pipe. Washer cycles and doesn't spin.
The float on the water level shut off valve is probally stuck and not telling the washer that its full and to turn off the water. once thats fixed it will probally cycle normally. Try it on half load and see if the water stops at the correct spot.
May 15, 2011 | Washing Machines
The water is overfill
Hi
Overfilling is caused when either the water inlet valve or water level switch is bad. When any of these parts goes bad it won't shut off the water and so cause overfilling. Hope this helps...please post back for further assistance.
Daniel
Jan 21, 2011 | Whirlpool AWZ410 Front Load Washer/Dryer
Kenmore washing machine Type 111 Model 110 - 26492503 water over flowing while starting the cycle. Not stopping on the level of water required.
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won't be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won't tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you'll need to replace the water inlet valve. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 07, 2010 | Kenmore 24032\24036 Top Load Washer
The washer is ovrtflowing with water. It does not stop
Hi
Thanks for using FixYa. Overfilling in your washer occurs mainly due to two things: water inlet valve going bad and/or the water level switch. If the water inlet valve has gone bad it won’t be able to shut off even when the electricity has been turned off. If the issue is with the water level switch then it won’t tell the water to shut off and the machine will overflow as this switch is to sense the water level in the clothes tub. However, with that being said it seems that you’ll need to replace the water inlet valve. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 07, 2010 | GE WDSR2080D Top Load Washer
Over filling
Hi
Thanks
Rylee
Sep 06, 2010 | Kenmore 24032\24036 Top Load Washer
Wont stop filling up. It will overflow with water
Hi
Thanks
Rylee
Aug 22, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Roper washing machine will only run one load every 12 hours!!
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Jan 21, 2010 | Washing Machines
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Maytag washer model # LAT8714A over fills
An overfill caused by a failed valve will occur even if the machine is unplugged. Trace amounts of debris from your plumbing etc or even a deterioration of valve parts themselves can cause it to pass water while off. This can be as slow as a drip but given time it will overflow. Water level switches are by necessity highly reliable parts and when they do fail they usually "fail safe" in other words not allow any current to the water valve. Overfills that are not due to a bad water inlet valve are usually traceable to a pinched, plugged or disconnected air hose. The location of the switch varies. Sometimes it's right behind the water level knob. On others like front loaders it's inside the machine, usually above the tub and at the end of a length of clear plastic tubing.
Jan 28, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
