Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | I have a 1999 big scr...
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
I have a 1999 big screen purgation mitsubishi tv
By invader_6669 on Jun 29, 2009
i have a 1999 big screen purgation mitsubishi tv and when i turn it on it go's to this ant-B and under that it would say stereo SQV and i can hear the show that is playing from the cable box but it dont show the picture but when i go to the menu for the tv and go to channel and it will show the picture for the tv in the box on the top right and when it was working the tv would come on and i would hit the input button four times to watch the tv but now it only has two input channels. i dont know how to fix it can u help me.thx
Solution #1
posted on Jun 29, 2009
Not Rated)
Skyassoc
Rank: Guru  Televisions & Videos  Expert
Rating: 90%, 255 votes
If you go into the Main Menu for the TV with the Remote, then into set up, look for a adjustment that says Monitor or TV.
It sounds like it is in Monitor mode.
Hope this helps,
Skyassoc
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
i have an older projection tv and the red yellow and blue dots are showing through.projection dots i... (More)
Answer
the TV will not turn on and the green light just blinks. The directions say to push the reset button... (More)
Answer
Mitsubishi W555809 TV won't start. Had a play station 2 hooked up for a couple of weeks and once... (More)
Answer
My dad's tv has sound but no picture mitsubishi television (model wd52528). BUT he messed with the... (More)
Answer
how do i remove and install the motherboard in my mitsu WS 55809 tv. thanks
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
