Question about Seagate Computers & Internet
Free Agent 1000GB is heating too much and stops working and want to know how to disassemble it to install a fan.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 13 Answers
This is from another site, but I think it has a good description
Be careful, some people report that taking these drives apart may damage the connectors, that are soldered to a circuit board inside the case.
Try these steps, I looked at my own drive and it looks like it has the same design as the one described here.
1. Remove the rubber feet
2. remove the screws from where the rubber feet were.
3. Remove the esata/usb base
4. remove the lower plastic cover
5. remove the tiny screws
6. remove the metal shield
7. remove the 3 base screws.
8. stick a standard screw driver into the lower holes and twist. One side panel will move, one will not. The removeable panel is the one with the logo that lights up. If you are looking at the drive from the back where the ports are, the panel is on the left.
9. Stick the screwdriver between the plastic of the panel that moves. this panel has 4 clips holding it on very tightly but it can be pryed off.
10. Once the panel is open, unplug the drive and remove it. It is in a metal free floating cage. Remove the rubber covers to reveal the screws.
11. Pry the two cage panels apart and the drive is free. There is no permanent damage to the case, so you should be able to mount another drive in it.
Posted on Jun 29, 2009
Overheating
Hello, welcome to Fixya!
Over heating maybe caused as a result of weak fan, ineffective heat sink, (dried thermal paste on the processor) or dust around the fan area in the system preventing free passage of air.
Also, where you keep your laptop when using it matters too. If you place your laptop on a foam, rug or too close to things preventing free passage of air may cause overheating.
You have to disassemble your laptop, and use a paint brush to remove every dust around the fan. Also, apply thermal paste on the processor to reduce the heat.
If you don't know how to disassemble your laptop, then you need someone to do that for you.
Take care.
Oct 24, 2015 | Computers & Internet
Unit was clipping out @ high volume.
First of all, I would need to know the make and model number, rather than guessing. Second question, why are you driving the amp into clipping, if that's what you mean? That will destroy tweeter and midrange drivers. Certainly, if you are driving it into clipping, the heatsinks have got to be hot, and I don't believe an external fan will cool the right places. If you can get back to me with more information, you can contact me at my website, audioserviceclinic.com, to inquire about a repair. Thank you.
Nov 27, 2014 | Audio Players & Recorders
Hp g6-1331 fan problems
Is it free of dust? the vents clean? Improve air flow.Try a can of Compressed air to blow out the fan and vents. Is it getting sufficient air flow from the bottom through the machine? You may have to disassemble the laptop. You didn't supply the Make and Model. I don't know what CPU you have. Their is a little freeware program SPEED FAN , but I don't know if it will work with your CPU, Intel South Bridge? Check the Description. You can try: http://www.filehippo.com/download_speedfan/
Mar 02, 2013 | Computers & Internet
I forgat pasword 1000GB my passport USB
My Passport is one of the external storage product lines produced by Western Digital, or WD. My Passport drives are designed for on-the-go use, unlike the enlarged devices found in the My Book series. Passports have slim cases constructed of heat-sinking materials such as aluminum -- which compensates for the lack of built-in fans. They range in storage capacity from 250 GB up to 1 TB, although out of the box this amount is diminished because of the installation of SmartWare, WD's user-friendly software. You can reset the password on My Passport from within the application if need be.
Click "Start" and select "Computer." Double-click the CD-ROM drive, then double-click the "SmartWare" application; on a PC, the application is listed as "WD SmartWare.exe," and on a Mac it is listed as "WD SmartWare.app." Click the "Settings" tab. Click "Set Up Drive." Select "Install" and accept the "End User License Agreement" when prompted. Click "Continue Setup." Open the "Security" tab. Type your current password into the box labeled "Password." Enter a new password and a new password hint. Confirm by checking the "I Understand" box and clicking "Update Security Settings." if this fails
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html
Support IDE/SATA/USB Hard Drives memory cards USB Memory Drives
Windows Password Cleaner
Available in Live CD to run offline
This is a utility to blank the password of any user that has a valid local account on your Windows system.
You do not need to know the old password to blank the password.
Hope this helps.
Dec 20, 2012 | Computers & Internet
Hi, my HP Compaq Presario has been working great till the 5th of July when it shut down unexpectedly. I instantly turned it on again and shuts down again after booting up. I waited for about an hour, then...
Due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked and resolved properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink. As you have mentioned that the fan is not running, most probably the fan has gone dead or it may have stopped working due to clogging with dust and hence it needs cleaning or replacement. To do so, you need to purchase a new fan and disassemble the laptop to replace the fan.
To replace the fan, you have to disassemble the laptop and for that you need to have the laptop repair manual that can be downloaded here.
(I think that you have HP CQ60-419WM Laptop). The repair manual contains all the information as well as graphic illustration about disassembling and replacing the fan. Please refer to Page 4-41 for complete details.
If you are able to work inside such electronics and have some disassembling experience, you may try to do it yourself. However, if you have no experience, it is strongly recommended that you seek professional help from HP authorized repair/ service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 06, 2011 | Computers & Internet
My sony is over heating
This is almost certainly a hardware fault - the fan will need to be replaced. This is a job you can do yourself if you are comfortable disassembling the laptop. Otherwise I suggest to take it to a repair centre.
Mar 04, 2010 | Sony CPU FAN CPU Fan
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Oct 30, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
No fan noise when cooking.
The internal cooling fan is critical. It comes on automatically whenever the oven is cooking.
If the oven is used without its working properly, the magnetron can be destroyed very quickly.
(This of course is different from the hood vent exhaust fan, which you can turn on and off at will)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
In some models, the motor itself is bad. In other models, it is a bad relay or connection on the control circuit board.
We regularly repair these control panel assemblies for customers nationwide with our guaranteed $39.95 service in about a week.
Feel free to contact me directly (with your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My Kenmore 64663 still heats but I don'y hear the fan anymore while heating
If it's the internal cooling fan, you really need to get that repaired before you cook anymore with it. Otherwise, your magnetron will be destroyed.
If it's the hood / exhaust fan, then the problem may be the motor or a problem on the control board.If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't feel confident to tackle it yourself, I would contact Sears for service.
Aug 22, 2008 | Kenmore 64663 Microwave Oven
KitchenAid KCMC155J
Sounds like a classic bad door switch or switch holder. If you or a friend decide to work on it, we have *critical* safety info, info on door switch testing and replacement, and oven disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://tinyurl.com/gv383
Mar 11, 2007 | KitchenAid KCMC155J Convection/Microwave...
Computers & Internet Logo
453 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
