Question about Symbol PDT 6846 Portable Terminal
The scanner says: File: e:.s24cfg.dat and then says, "press any key" but when I do, it doesn't do anything...
    Problem Solver:
  • 5 Answers
You may need to reload your terminal.
For a free phone troubleshoot, contact Lexicon Technologies.
Call: 1-800-678-1744
Email: techsupport@lexicontech.com
Web: www.lexicontech.com
Posted on Sep 10, 2009
Will not feed 11x17
You probably need to set the user settings to "long doc" mode.
1) When the machine is in the standby state,
press the NEW FILE key and Count Only key
simultaneously. During the user mode, the
LEDs of the NEW FILE key and Count Only
key illuminate and the address (U01-U10)
and data (the last digit) appear on the
counter display.
2) When changing the address, use the NEW
FILE key. Each time NEW FILE is pressed,
the address changes, cycling from U01 to
U10.
3) When changing the data, use the Count Only
key. Each time Count Only is pressed, the
data changes.
4) Pressing the Stop key exits the user mode.
Long document mode =U10; 0=normal and 1=long document mode.
Happy Scanning!
Scan-R-Store
Scan Store provides service and maintenance contracts on all Canon Fujitsu...
Apr 02, 2014 | Canon DR-9080C Path-Through Scanner
Tip
Barcode scanner reapir tips
Loading Scanner: With the scanner powered off press and hold the SHIFT key & BK SP key on the scanner. While holding those two keys down press power, let power key go and then let SHIFT and BK SP go. The scanner will now go thru a reboot process. When done the scanner should read:
“ COMMAND MODE “
Select function
Self Test
At this point press the up arrow key twice and the scanner will now read:
“ COMMAND MODE “
Select function
Program loader
Place the scanner in the cradle and press enter. The scanner may or may not give a message saying “ WARNING: EEPROM WILL BE ERASED CONTINUE? “ At this point push enter. Let it erase the EEPROM. When done the scanner will ask you for “BAUD” press the up arrow twice and the scanner should read 38400. Press enter and, the scanner will ask you for “data bits”, press the up arrow key for 8 bits. The scanner will now prompt you for “flow control”, press enter. The scanner will now be on a screen that says:
“COMM Parameters”
Start? <ENT>
Just leave the scanner at that screen for now.
There is a file you need to test its called Diags.hex that needs to be transferred to the unit. once that is downloaded you can test the laser memory and even the keyboard.
on Dec 01, 2009 | Computers & Internet
Unlock hame compatible with celcom 3g
1. Go at A11W UI by set in the URL of your browser the address 192.168.169.1 2. Go at the Login > Admin > Settings 3. At the end of page press the Export Button. Now, a file with name RT2880_Settings.dat will be saved in you hard disk. 4. Open the .dat file with notepad program. 5. Search for lines "CountryRegion" and below "CountryRegionBand". After symbol "=" delete the value (ATTENTION, lines to be remaining one below the other). Save file and close. 6. Repeat steps 1 & 2 above 7. Below button Export select button Select File. Press and select the .dat file tha you save before. 8. Press Button import. The .dat file will be load your new settings and A11W will restart. 9. You can use after any supported SIM card around world. Good lack!
Feb 05, 2013 | FocalPrice HAME A11W 3G 7.2M Integrated...
Power butoon works and the others seem not to function
Is the display showing an icon that looks like a key? If so, you have unintentionally locked the keyboard. To UNLOCK it, power the scanner ON and then press the FUNC and key (picture) keys. If that doesn't work you will need to RESET the scanner. To do this, power the scanner OFF, then press and hold the 2, 9, and HOLD keys while you power the scanner ON. The RESET will erase all your programming, but it will get the unit working again.
Bill B.
Listening in since the 60's
Jun 25, 2011 | Uniden BC92XLT Handheld Scanner
Cannot find directory in commamd prompt
you want to open commamd prompt? press start+R and type cmd
Oct 26, 2010 | Computers & Internet
When i start my hp scanner then 1 warning show. the warning is " where is the file of hpf2vw10.dat " so what can i do ? pl. help me.
Uninstall the scanner drivers and install them again from the cd given or downloaded from online.
The dat file is missing due to corruption or a bad install.
Dont worry. This should solve the problem. Cheers!
Aug 16, 2010 | Computers & Internet
How to make a VC5090 auto send a carriage return after each scan
In the Wavelink TE can you setup the an Tab after Scan option for the 3270 emulation. For other emulations are there similar choices. Please check the Wavelink settings on the desktop machine and the upload the modified config files to the unit via ActiveSync.
Apr 29, 2010 | Symbol MC9090-G RFID Handheld Barcode...
MP7001 - SCAN FILES ARE BEING SENT TO EMAIL AS A DAT FILE INSTEAD OF PDF
Press the Scanner button, on the left hand side of the LCD screen there should be a button that says "file type" press that and change the current setting to multi-page PDF. Now press ok and you should be back to the main scanner screen. on the right hand side of the control panel above the numbers press the program key, now on the LCD screen press program as default a window will pop up asking if thats really what you want to do, just press yes and you should be good to go.
Dec 09, 2009 | Ricoh Office Equipment & Supplies
New version of window live
hi,
u've to delete a (index.dat) file.
in Vista
C:\Users\<UserName>\AppData\Local\Microsoft\Windows\History\Content.IE5\index.dat
in XP
u've to go this link and remove each index.dat file.
http://www.codeode.com/privacymantra/locations/index.dat/index.html
Sep 18, 2009 | Microsoft Windows XP Professional SP2 Full...
Have Quicken 2008 and HP J6400 printer. Can print reports but can not print checks
Check that the problem is not caused by mismatched paper size, in that case you may need to correct printer settings and adjust also settings on Quicken.
Quicken 2008 is also known for having several bugs that affect printing, if you are considering an update to 2009, that should fix the problem.
You can also check if a patch to fix the problem is available contacting quicken online, check the links below:
Quicken® Personal Finance Software: Chat
Get Help with Quicken | Quicken Help and Support Options
Regards.
Jul 27, 2009 | Computers & Internet
Symbol PDT 6846 Portable Terminal Logo
207 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
