Question about Brother MFC 420CN All-In-One InkJet Printer
No Power to printer after a electrical power line surge
  • 30 Answers
Check to see if its plugged in.
Posted on Jun 29, 2009
Why doesn't my printer power uu and can it be fixed"?"
Hi, Diane it is possible the power is bad, but if you wish to remove the inks you open the ink door cover and then gradually pull the carriage. please note that it would try resisting the pull.
Aug 22, 2014 | HP Office Equipment & Supplies
MFC-8710DW has no power
If your Brother machine does not appear to have power,then check whether or not the date and time appear on your Brother machine's LCD. If anything is displayed on your Brother machine's LCD, then it is most likely receiving power.If your Brother machine's LCD is blank, continue to Step 2.
Verify the Brother machine's power cord is connected securely to the power outlet. If you are using a surge protector, extension cord, or power switch, disconnect it and plug the Brother machine directly into the wall outlet.
Please note Brother strongly recommends that you connect your machine to a surge protector.Because To protect your investment against power surges and lightning,
In particular, we suggest that you use a surge protector that is compatible with both standard A.C. power cords and telephone line cords. Surge protectors equipped with telephone jacks will assist in insulating your machine from any power surge that might travel through a telephone line.
If the Brother machine is turned OFF, its LCD will be blank. Please make sure the Brother machine is powered ON by pressing and holding the On/Off or Power Save key. This key is located in the upper-right corner of the control panel.
If your Brother machine's LCD is still blank, connect it to a completely different, known working power outlet. If the Brother machine powers up, then the problem is related to the original outlet.
-OR-
Confirm the power outlet is working by plugging another known working device (a lamp, radio, etc.) directly into the same outlet. If the other device does not work, the problem is related to that power outlet. If a wall switch controls the outlet, verify that the switch is ON.
If your Brother machine still will not power on, please contact Brother Customer Service.
Or
Please Follow Us On Brother Printer Support
Jan 02, 2014 | Brother printerall-in-onelaser mfc8710dw
All LED lights flashing on Brother HL-2140, how do you clear it?
Your printer needs servicing due to a fault on its electronics. This is due to a power surge or spikes cause by an abnormality in your power distribution system or your power transmission/distribution lines might have been struck by a lightning during a storm and its breakers have failed to cut the power.
As a precautionary measure, always plug electronic devices on surge protectors.
Send your printer to your nearest Brother Service Centers.
Jan 19, 2012 | Brother HL 2140 Laser Printer
Lost our power and now it won't turn on.
Yes , usually you will need the manual to know how to replace it
In my experience the fuse blow due to something that is electrically faulty in the unit and changing the fuse does not remedy the issue. You may have a power supply issue that a reputable service tech will have to determine if it is malfunctioning in this area.
Jun 18, 2010 | Lexmark X2500 All-In-One Printer
If I open and close the printer it starts as if it is doing printer prepeartation, but nothing comes on. The screen will not turn on.
  • SOLUTION 1 If the HP All-in-One is turned off, press the On button to turn the unit on.
  • Unplug the power cord from the back of the HP All-in-One.
  • Wait 15 seconds.
  • Plug the power cord back into the HP All-in-One.
  • Turn on the HP All-in-One by pressing the On button.SOLUTION 2: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
    1. Unplug the power supply from the rear of the product.
    2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
    3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
    4. Wait 15 seconds.
    5. Reconnect the power cord to the power module.
    6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
    7. Check to see if the power module has an LED.
      • If the power module does not have an LED, continue to the next step.
      • If the power module has an LED, check to see if the LED lights up.
        • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
        • If the LED lights up, continue to the next step.
    Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
    1. Reconnect the power supply to the rear of the product.
    2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down.
  • Apr 07, 2010 | HP Photosmart C6180 All-In-One InkJet...
    Printer keeps telling me to reinstall print cartrige. will not print any documents
    4. Wait 15 seconds.
    Thanks
    TechSaver
    Jan 21, 2010 | HP PSC 2175 All-In-One InkJet Printer
    No power after storm last night
    this kind of power surge from an electrical storm would have taken out the nvram chips on the boards get a new printer and install it using a a surge protector
    Nov 26, 2009 | Lexmark X5470 All-In-One InkJet Printer
    Will the phone line power surged damage the printer?
    wow! You need a new main circuit board which costs as much as a new mfc.
    Apr 23, 2008 | Brother MFC 420CN All-In-One InkJet...
    Power supply failure
    might be a defective one, must contact the manufacturer.. no good on this one
    Mar 25, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
    Brother MFC 420CN All-In-One InkJet Printer Logo
    79 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Victorman
    Victorman
