I have already changed the mother board on the bottom of the machine, I checked the motor with a 9 volt battery and it does run, and I just changed the display board and did the calibration and still reads l5 error after calibration. Any other options?
SOURCE: the machine will quit wright after you start and
Had my TC5000 for a year and this is the first time this happened. I use it everyday. Googled "Bowflex Teadclimber error codes" and found this link download.dfxi.com/supportdocs/AM/Bowflex/BFX_TC135_AM_2008.pdf which is a pdf manual.
I'm going to try this fix now, hope it works for you and me
Here's what it says for ERR LS:
Belts stop turning and “err LS”
or “err OS” is displayed
Calibration Re-calibrate machine using Owner’s Manual
calibration procedure.
Speed sensor 1. Cycle power off and on.
2. Put the machine in calibration mode (see Calibration
procedure in Owner’s Manual) but do not
start the calibration routine.
3. Remove right rear plastic cover to view LED
diagnostics on control board.
Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board.
LED may be lit or unlit.
5. Manually advance the treadle with your foot,
and check if LED D is blinking.
6. If LED D is not blinking, then the speed sensor
is not supplying a signal. Check that the speed
sensor wire is plugged into the motor controller
board, to the connection labeled “P1”. Check
connection of speed sensor to jumper wire.
Check speed sensor adjustment (use business
card to set gap between sensor and pulley). If
LED D still does not flash replace sensor.
I/O cables If LED D is flashing when the belts are turning
but err LS or OS persists check connections and
for signs of visible damage to any of the three I/O
cables. If no damage, check continuity using a
multi-meter. If a multi-meter is not available contact
customer service for replacement cables
and further assistance.
Mike
SOURCE: After approx. 30 min. of walking on full speed it
I had this happen on our machine after about 5 years of use. I just recalibrated it and it appears to be working fine now. See the manual for information on the steps needed to take in order to do this.
SOURCE: who can repair my bowflex treadmill 5 series in toronto
There are four typical causes for this problem : 1) The walking belt and/or deck are worn. (85% of the
time)
2) The walking belt and/or motor belt are too
tight- if you have adjusted either recently. (8% of the time)
3) The motor has lost torque and needs brushes or has
demagnetized. (5% of the time)
4) The controller board is
dropping output. (2% of the time) . You can do it foryourlsef. However i will give some websites FOR TO CONTACT THEM:
www.unitedassemblers.com + www.treadmildoctor.com
Sincerely. Merry Christmas.
ERNESTO CUADRA
MANAGUA, NICARAGUA.
time)
ERNESTO CUADRA
MANAGUA, NICARAGUA.
