Question about Hotpoint 18.2 cu. ft. Top Freezer No-Frost Refrigerator CTX18DABWW
Hotpoint ctx18 ref has water on floor on defrost cycle
This is no drip pan for this model so how does the water not end up on the floor during a defrost cycle
    Sniper:
  • 68 Answers
The pan is not removable. this model has a pan the water drains to, that the condenser lines run though also. the heat from the compressor and the exchange lines evaporate the water.
Posted on Jun 29, 2009
  • 999 Answers
Look on or under the compressor. There is a drip pan there.
Eric
Why does water drip inside the ref toward tne rear of the ref? Happens once a day
That's the automatic defrost cycling. The water collects at the bottom and drains into a flat pan underneath for eventual evaporation.
Jul 19, 2014 | Hotpoint Refrigerators
During the defrost cycle our refrigerator leaks water from the freezer side out the front into the floor of the kitchen. Where could it be coming out and what will fix it?
The water from the melting ice during defrost should be guthered from the drip drain pan which is under the evaporator pipe coil and is passing though the drain tube which is conected to the dip pan and should end out on the back of the fridge to the compressor to evaporate. The problem posibly is that the drain tube is goggle either from ice or from dirt or both and the water since it can not end to compressor it overfrow from drip pan inside the freezer. So you can clean the drip pan and drain tube using a wire rod and problem will be solved.
Sep 13, 2011 | Refrigerators
The unit is dripping water on the floor. I don't find the drip pan does the HSS25GFP have one if so where is it?
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 21, 2011 | Hotpoint HSS25GFP Side by Side...
Our Jenn-Air refridgerator is 11 years old and is leaking from the back onto the floor. We looked in the back behind the cardboard panel and saw that the pipes around the( pump ?)located in the lower...
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 11, 2010 | Jenn-Air Refrigerators
HOT POINT FRIDGE - FREEZER DRIPS WATER
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer.
Jul 12, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water on floor in front of freezer section every day or so.
At the back of the freezer is locate the evaporator and below it is a drip pan to collect the water produced during the defrost cycle. Some equipment defrost every 12 hours so that is why you see the ice formation at mornings. You need to flush the drain hose by blowing with compressed air, or suction ut from its end below the outback of the unit. Also you can use a flexible ;plastic rod and carefully pass it thru the hose from the bottom ow the drip pan.
Jan 18, 2018 | Frigidaire FRS23H7CS Side by Side...
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Jun 26, 2010 | GE Hotpoint® HTS18GBS Top Freezer...
Hotpoint 18.2 cu ft refrigerator -water pooling on the floor
Was it the tubeing that drains the defrost water that you cleaned. Did you clean it at the top where it would be stopped up with ice. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If not
Aug 15, 2009 | Refrigerators
I HAVE A KENMORE REFRIGERATOR THAT LEAKS WATER UNDERNEATH EVERY COUPLE OF DAYS. IT DOES NOT HAVE AN ICE MAKER OR WATER DISPENSER. I THINK I NEED TO DO SOMETHING WITH THE BLACK TUBE RUNNING DOWN THE BACK...
Jul 12, 2009 | Refrigerators
Samsung Fridge Freezer leaking water
hi August.
Cause: A blocked defrost drain is one of the most common causes of water leakage. This happens when food particles or other debris clogs up the drain hose, which can lead to ice buildup and, eventually, water leaking out of the freezer and refrigerator.
3 common refrigerator problems you can easily fix yourself
The freezer drain hose will drain the defrost water into a drip pan at the bottom of the freezer. When this pan becomes full, it will leak water onto the floor. This is a regular maintenance task whenever the freezer defrosts. Empty the drip pan during the defrost cycle.
How to Fix Water Leaking From the Bottom of Freezer
Why is my fridge leaking water on the floor? If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.
SOLVED Water leak in refrigerator Refrigerator
Dec 03, 2017 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
558 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
