Question about Delphi SKYFi XM Radio Receiver
No signal on Skyfi3 XM radio.
Got a signal two weeks ago. Starting up again and nothing. I've tried three different antennas in different location. Refreshed radio. Downloaded new firmware.
SOURCE: trying to update firmward on Delphi SKYFi3.
I have the same problem and the person I just spoke to said there is definitely a problem with the radio itself and told me to return it to the store! I told her I bought it five months ago and asked if that would be a problem and she said it would not. This should be interesting...
Posted on Apr 27, 2008
  • 5 Answers
SOURCE: Downloading instructions Delphi SKYFi3 unit
You can't download Xm programming, like you can from itunes, where you get a song in 3 or 4 seconds.
Do you mean record music? You must record realtime, either while listening or while the unit is idle in its cradle.
It's easy. while listening to the radio in the cradle (press mode repeatedly to get to Live XM mode), then press the center (play/pause) button.  the menu will pop-up, select Record.  It will give you the option for Song, Channel, and Session.  Just chose one of the first two and press the button.  You should see a microphone appear at the top of the screen.  It's recording.  Follow the same steps to stop the recording.  Setting up a recording session is self-explanatory once you get into that screen.
Posted on Dec 19, 2008
dmftrucker
  • 1922 Answers
SOURCE: No audio through car radio
is your car radio and the xm receiver tuned to the same frequency?
Posted on Aug 31, 2009
  • 4 Answers
SOURCE: Skyfi3 stuck in Detecting SD Card mode - tried
8GB card is a SDHC card, and these units were designed to read SD cards. At a glance, you would think it shouldn't make a difference, but data is stored differently on SDHC because of expanded capacity than SD cards. I, too, learned the hard way; purchased storage card before researching "processing" capabilities of the Skyfi3 units.
Your card should work fine in a Cell phone or other devices specifically designed for SDHC cards. Hope you get some use out of it.
Posted on Aug 13, 2010
TOLhamRadio
  • 509 Answers
SOURCE: Problem with the Delphi SKYFi3
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Posted on Oct 06, 2010
Help Audiovox Onyx
Its because of the tall buildings and all the power around you breaking the signals.
Apr 23, 2013 | Audiovox Xm Onyx Sirius Xm Satellite Radio...
When using headset with skyfy3 display says check antenna .
Are you using the special Delphi headphone with the built=in antenna? There is NO antenna built into the SkyFi3 like the MyFi - you must have the special headphones with the antenna built in. okay?
Jan 18, 2011 | Delphi SKYFi3 XM Radio Receiver
XM Receiver: When hooked up to the home kit it will show antenna and will not pick up a signal. When hooked into the car jack it works ok. I replaced the receiver mount about 3 weeks ago and it worked ok...
Hi Kldeaton,
If you can do it, try your car mount in the house, as long as you can supply power via the car plug (12-volts DC). If it does the same thing as the home kit, then you more than likely have an intermittent antenna connection on your home antenna.
Also, check the location of your antenna vs any obstructions, such as trees. You may have the reception worked out so that you have signal from the antenna, but it is "breaking up" from a connector or cable short or open condition. Check the coax for any chaffing also. Let me know if you need more help. Thanks.
Regards, Bill
Sep 28, 2010 | Delphi Roady XT XM Radio Receiver
Skyfi3 stuck in Detecting SD Card mode - tried popping SD card in and out a few times - that didn't work. Tried pressing the Mode button and the volume plus and nothing. Tried to XM Firmware Update and...
Feb 18, 2010 | Delphi SKYFi3 XM Radio Receiver
Aug 31, 2009 | Delphi SKYFi XM Radio Receiver
Delphi SKYFi3 XM Radio Repeater
You begin by setting up your existing (((XM))) antenna the one that came in your home kit (not included in repeater package) in a location that gets good reception of the (((XM))) signal. This may be outside, or on a south facing window sill. This antenna gets plugged into the rear of the Delphi (((XM))) Radio Signal Repeater Transmitter. A power jack is right next to the antenna connection, and should be plugged in and to the wall with the included power supply. There is also a "PWR OUT" selector switch on the rear of the unit which allows you to control the strength of the signal transmitted from the unit.
Once the power and antenna are attached, both blue indicator lights will light up on the face of the unit. The blue antenna indicator will light up only to signify that the antenna is attached correctly. It does not let you know whether your antenna is in a location receiving a good (((XM))) signal or not. You will have to look at the signal strength indicator on your (((XM))) radio receiver do determine best location for the (((XM))) antenna.
Once you have this setup, place the Repeater Antenna close to your existing (((XM))) Radio and plug it into your antenna jack on the (((XM))) radio cradle. This connector is identical to your (((XM))) Home Antenna provided with all Boom boxes and (((XM))) home receivers and kits so compatibility is guaranteed. The Repeater Receiver Antenna does not require any separate power connections. Hope this helps!
SATELLITE RADIO WAREHOUSE
Jul 10, 2009 | Delphi SKYFi3 XM Radio Receiver
No Signal on my XM Radio
Lately I have been loosing the signal constantly in the house. I've tried different stations to see if it would be any better and it's not. I called xm and they refreshed my signal but it didn't do ant good. It's really annoying to constantly have the signal fade. Everything is hooked up right. This is been going on for about 5 months and my neighbors complain about the same thing.
Any Suggestions
Jul 30, 2007 | Audiovox XCS9 XM Radio Receiver
No Signal
Try another antenna...Maybe the other one got a cut in the wire or somehow malfunctioned.
Mar 28, 2007 | XM Radio (XMP6000)
Delphi SKYFi XM Radio Receiver Logo
194 people viewed this question
Top Delphi Audio Players & Recorders Experts
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
