Question about Hayward SAND FILTER, PRO SERIES
When vaccum dirt, comes back in thru jets. \have a hayward filter
Looked at spyder gasket, looks ok
5 yrs old...never changed sand
inground pool
  • 110 Answers
Do you back-wash your filter regularly?
Sound like dirt build up.
Posted on Jul 07, 2009
Not filtering
too many chemicals will cloud contact the company website or did you maybe its the water change the water
Feb 28, 2017 | Pentair Tagelus TA 60D Filter
Every time I vacuum, dirty water comes in thru jets. Help
One of two things is happening, either the sand has worn smooth or the the multi-port valve has gone bad, sand only lasts 3 yrs max.
Jun 01, 2013 | Hayward SAND FILTER, PRO SERIES
I have 7 year old Hayward ProSeries, S-244S, H/R Sand filter. I've notice that when I vacuum the pool, dirty water returns to the pool. I've backwashed and the spider gasket is fine. No sa
sand filters only have limited filtration. If the dirt is very fine such as dead algae, it will go right through the filter. Use a clarifier to help give the filter finer filtration. Do not vacuum until you can see what you are doing, then vacuum on 'waste'
Sep 19, 2012 | Hayward SAND FILTER, PRO SERIES
Spitting dirt back into the pool.
Check the standpipe gasket. Its a small part, but could be the problem. Also, look very closely at your manifold for any small cracks. The smallest fissure in the manifold can produce big problems.
Jul 20, 2012 | Hayward SAND FILTER, PRO SERIES
I just finished cleaning my pool when I noticed debris around the area where my inground pool jets are. So I backwashed and vacuum that area. However, once in filter mode I noticed sand at the bottom of...
When sand comes back from the filter, that means that the device inside the filter that keeps the sand in has broken. In order to replace the item, all of the sand must be removed and the tubes must be removed and new ones installed. Go to your local pool supply house with your filter information and they can show you how to remove your old units and they will sell you new ones. You only have to replace the ones that are broken.
Gary
Aug 12, 2011 | Hayward SAND FILTER, PRO SERIES
Have a sand fikter pool is constantly dirty and green was great all summer cannit see sand coming thru jets water clear and checks good
You may need to change your sand in the filter, depending on it's age. You should have a qulified repairman check this for you and do the job if nessary.
Aug 08, 2011 | Hayward SAND FILTER, PRO SERIES
Our sand filter is not filtering the water clean. We have changed the sand, but I have to backwash it every other day or the dirt comes back out through the jets. What is the problem and how can I fix...
Make sure you used #20 silica sand a smaller sand will do this. Also if you have alge be sure all the alge is dead or it will get through the filter. You can probally kill alge with liquid chloriene. Start with about 10 gal. chlor. per 10,000 gal in pool.
Sep 03, 2010 | Hayward SAND FILTER, PRO SERIES
I changed the sand and i can only vacuum about 2
Try consulting the owners manual for these pool filters. It will give you a lot of info in the settings that your filter needs to be on to do specific tasks. I really think that it will help you get this straightened out.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
We have found sand in the bottom of our inground pool we have a hayward pool sand filter what could be the reason
have you added sand to filter if so may be to much make sure that handle is in the right position check by changing setting several times to make sure sprocket under handle is not damaged sounds likeit is not seated
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
I have a hayward s200 sand filter. When I vacuum, i backwash but dirty water doesnt seem to backwash out, just clean water. When I turn filter on small amounts of dirt you cant see come out of jets and re...
Are you using the rinse setting for a few seconds following the backwash? If not, once you finish washing, stop the pump, change the valce to rinse, then run it about 3 to 5 seconds. Shut down then switch to filter and the particles should stop coming back to the pool.
Jul 05, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
221 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
