Question about Tools & Hardware - Others
My Dad has a used ryobi router RE600 and there seems to be a switch for maybe speed control? is missing. We would like to find out where to purchase the part. Thanks. takertim@hotmail.com
    President:
  • 1,996 Answers
Have a look here. and click on the parts list to open a pdf you can read. It's probably part 21 or 22, the dial or the speed control circuit module. Ryobi is always hard to find parts for. They seem to have released different models in different parts of the world, and their search database leaves a bit to be desired...
Here and here are two links to sources I've had some success with.
Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 29, 2009
My Ryobi 10" Compound Miter Saw (with laser) will not turn on when I push the button. Nothing happens at all. Its as if a safety switch needs to be turned off, but I'm not finding one.
you did not give model number. The saw should not be used without blade guard uncles you are to attached to your fingers. the power switch may be bad or it could be motor. Should not buy used power tools without ensuring that is operating properly. Here is a site that sell replacement pars. be careful that the price of repair parts plus the purchase price does not come to more than 50% the price of new tool
https://www.toolpartsdirect.com/
Jun 12, 2018 | Ryobi Saws
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Freud ft2000 switch
You can find a part diagram and parts list on-line. Just enter the model #. The variable speed control module is no longer available. You can bypass the control, and connect the router directly. You will no longer be able to control the speed, or turn off the router. I used a variable 15A control box instead. It will function the same way.
You may want to just replace the router with a new up-to date router, I just purchased a 2 1/2HP Skil router kit tah has a 1/2 chuck, and both a plunger base a flat base, for $100 at a big box store.
Mar 23, 2014 | Freud FT2000E 3 Router
How easy is it to purchase a collet 1/4" wrench for the Ryobi R163K router 8.5 amp
Ryobi part number 671250001 . This is the wrench the tool came with.
You can order from Ryobi 1-877-545-4099 or go to their website, find the closest service center, and order it through them.
Nov 22, 2010 | Ryobi Tools & Hardware - Others
Disconeted from router and internet
in the router sittings remove the idle time for disconnecting and make it keep alive
Jul 04, 2009 | Computers & Internet
I just purchased and installed a Hampton Bay palm beach 48' ceiling fan (close to ceiling mount)Problem is when turned on I hear an annoying hummmmmmmmmmmm, more of a hum at high speed and it graduates...
You have a rotating dimmer switch on the wall to control speed right? If so, it is the wrong type switch. The missed matched switch will cause the humming. Use a regular on/off switch and control speed with the pull string
Apr 29, 2009 | Madison Avenue 04317 Hampton Bay Ceiling...
Ryobi Scroll Saw runs at maximum speed
Unfortunatly the speed controls cannot be repaired, they can only be replaced. You will have to find a Ryobi dealer in your area and get a new speed controler.
Mar 01, 2009 | Saws
Rf1101 makita router lost serious power and is sounding wounded
You dont have to take the armature out to look at the commutator, just remove the brushes (unplug tool first) and get a flashlight and look into the brush tube and slowly turn the shaft by hand and look for a discoloration or unusual look on the comm bars. The slight burned smell might have come from the speed control or the switch itself, but look at comm and then go from there. You can get a breakdown for this tool at Makitausa.com. Let me know if you need any more help
Feb 19, 2009 | Makita RF1101 Electric Routers, Fixed &...
Ryobi RE600 plunge router binds on the posts
Are you cleaning the area that contains the springs also and if so I would use something like a dry lubricant so that it won't attract more dust and dirt but we both know that eventually it will. Coat the posts with this and allow to dry and then push up and down on the motor to lube the bushings and you might have to do it again. You can also try a small amount of 3 in 1 oil but use sparingly.
Feb 16, 2009 | Ryobi Tools & Hardware - Others
Wireless router
I have a friend that works at 2 wire. I've bought a couple of their products. And I'm a computer geek. Unless I miss my guess it shouldn't matter what is plugged into it, be it laptop or desktop. It may be locked down to the MAC address on the NIC, but I doubt it. Anyway you'd just browse to it's embedded webpage and change the setting. The IP address is the same as the gateway address on the laptop plugged into it.
I think I bought that model for my dad but I can't remember the exact model number on it. Anyway the one I bought, and set up for my Dad, I had several different computers hooked up to it and never had a problem.
Nov 08, 2007 | 2wire (1000-400108-001) Router
Tools & Hardware - Others Logo
200 people viewed this question
Top Tools & Hardware - Others Experts
John Trevino
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
