Question about Toshiba Satellite A75-S209 Notebook
Toshiba laptop a75-s209 maximum memory capacit 2.5 mb
Can we make it more than this. two slots for pc2700 ddr 333 each 512 . can we make it 1G each . laptop built in with 512 mb memory.
    President:
  • 2,692 Answers
1.5GB total maxium, if I read the toshiba litature,correctly. So the answer is no, you may not. THe BIOS will only be able to read and use the max it was programed to read.
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835414&rpn=PSA70U&modelFilter=A70-S259&selCategory=3&selFamily=1073768663
Posted on Jun 29, 2009
  • Toshiba Master
  • 2,404 Answers
Here is the info straight from the toshiba user manual for your laptop:
Memory
• 512MB (Min)/1536MB (Max) (512MB on-board model). PC2700
DDR333 SDRAM 2.5V SODIMM Memory modules; configurable
from 512MB to 1536MB
It can't be 1 GB each cause the motherboard isn't enginereed that way to recognize the memory in that fashion. Hope this helps.
I installed a DDR pc2700 into my gateway 310S, it did not respond, how do I get it to respond?
Heres the specs for that model PC
Memory Type: DDR PC2700, DDR (non-ECC)
Maximum Memory: 1GB
Slots: 2
Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot.*
Maybe its time to upgrade the PC.....cheers from Scott
Sep 18, 2011 | Gateway 310S (2900621) PC Desktop
How much ram can I install on my Averatec 2200?
The ram maxes out at 2GB. There is only one memory slot, so you would need a 2GB memory stick. Hope this helps.
Regards,
Matt
Apr 15, 2011 | Computers & Internet
When i try to boot my toshiba a75 laptop i receive a boot last good ... it won't boot i removed memory module i installed 2 yrs ago and it boots ... i purchased new memory module and get same error- it...
Below are the specs to the type of memory that can be installed in the A75...it is very specific and cannot be anything else then what is listed. You have 512 mb built onto the motherboard, with one expansion slot. That slot can only hold up to 1 gb stick if the BIOS has been upgraded. Go to Toshiba support and make sure the BIOS on the machine is up to date so it will accept the larger stick of ram memory and make sure all the specs are right on the stick that you have.
Each memory slot can hold DDR PC2700 with a maximum of 1GB per slot.*
  • Maximum Memory: 1536MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 512, 768, or 1024MB (512MB non-removable)
  • USB Support: 2.x Compliant
  • Oct 20, 2009 | Toshiba Satellite A75-S231 Notebook
    PNY DDR PC2700 Optima Memory 1GB not recognized by A75 S209
    there are basically three different kind of ram so dear if its not working go out there and get the compartible one for your computer pls dont destroy that baby of yours.
    Jul 05, 2009 | Computers & Internet
    Adding memory to a a75-s211
    How much memory did it have before you removed the 256Mb RAM?
    If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
    Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
    Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
    COMPAQ LAPTOP MAMORY EXTEND
    This laptop has 2 slots
    So maximum memory supported is 1GB.
    If you install more memory there is a high probability it will not be recognised.
    You can get more information and order memory from the link below:
    http://www.crucial.com/store/listparts.aspx?model=Presario%20M2000%20Series
    Jun 08, 2009 | Compaq Presario M2000 Notebook
    Change RAM in Toshiba Satellite A75 notebook
    The Toshiba Satellite A75 came with either 256megs or 512megs of NON-REMOVABLE RAM. You will be able to insert a 256meg, 512meg or 1024meg stick of RAM in the slot. There will only be ONE slot to put the memory into. The only other socket on that computer will be for a wi-fi card but you would not be able to stick memory into that slot. The type of memory you will need is DDR333, PC2700, 200 pin SODIMM, 2.5 volt sync.
    Apr 05, 2009 | Toshiba Satellite A75-S209 Notebook
    Open Questions:
    Toshiba Satellite L15-S104, Model PSL10U-01X02F--A COMPLETE LEMON! 2-14-08 I purchased a Toshiba laptop in May 2005 at Best Buy in Montclair, California and all was good for a short time. Less than a year later I began to have so many problems. I took laptop to Best Buy Geek Squad and the hard drive had to be replaced! I had an extended warranty, so not any cost to me. I continued to have problems with the laptop and in took my laptop back to the Geek Squad in January 2008 and was told the laptop needed a motherboard at the cost of over $600! The warranty had ended. I have called Toshiba apx 4 times and finally given to a case manager and left on hold each time from 10 to 17 minutes! I have left messages and not anyone has returned my call. I have requested that my laptop be replaced. Christine Honea-Takata CHoneaTakata@msn.com Ever since I bought my laptop in December of 2004, I've had nothing but problems. My laptop overheats and shuts down repeatedly, the screen freezes, my sound only works 75% of the time, etc, etc. I have a stack of paperwork from the Geek Squad for numerous repairs - they've replaced everything at least once, some parts multiple times. They finally told me it was a lemon and that they were sending it in so that I could get a new lap top....6 weeks later I hadn't heard anything and called them - the usual waiting on the line, talking to 4 different people, them saying they'll call me back. A few days later I still hadn't heard back from them so I called again - same run around. They then told me that my lap top wasn't a lemon and that there was nothing they could do for me. I bought an extended warranty (3 years) and it's been in every few months - also meaning I'm without my blimmin' lap top for at least 2 weeks at a stretch. After my warranty ran out, I "gave up"...what more could I possibly do? The machine was a lemon from the start but Toshiba won't own up to anything. However, I know there was a class action law suit filed...haven't heard anything about it for the past year or so. I wouldn't touch a Toshiba with a ten foot pole. Terribly disappointed, angry and frustrated. I've lost huge amounts of data and had nothing but problems with customer service.
    Apr 06, 2009 | Toshiba Satellite A75-S209 Notebook
    Toshiba Satellite A75-S209 Notebook Logo
    305 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
