Question about Carrier 38CKC042 Air Conditioner
My ac unit is working but the room is not reaching the desire
Temp. air is blowing from the vent and the evaporator is working, why the unit keep going and the room is not cooling?
  • Robotinner May 11, 2010
    the evaporator is on the inside of the house and the condensor is on the outside would like know if you feel hot air blowing from condensor outside
  • 43 Answers
Is the condenser outside unit working. (Evaporator is inside the home.) If so you may be low on refrigerant. Have a qualified technician test it.
Posted on Jun 30, 2009
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
Only blowing hot air and red light flashing on panel. Also no noise from the main unit on the balcony which is usually loud when a/c in use
Whenever there is problem in unit, the error code will be displayed. Please check. As per your statement, it's communication error between indoor and out door. Check power in out door unit.If not check your temp setting.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working . Thanks.
Jan 07, 2011 | Heating & Cooling
Why doesn't it get cooler ?
you may have a dirty condensor coil its the coil near where the warm air blows out or maybe a dirty evaporator coil its where the air gets sucked in check both of them and then see whats the air temp going into the evaporator and the temp. coming out of the vents that blow cold air the diffrence should be about 15 - 20 deg f let me know what the temps are ...but first clean the filter and both coils
Jul 06, 2010 | Amana AP095R Portable Air Conditioner
Ice on the evaporator
Make sure the coils are not dirty,if they are not dirty,add freon to the system,not much,feel the evaporator,when the evaporator is cool all over,and the condenser is warm all over,there is enough freon,add very little at a time,this system does not hold much freon,if this was helpful,at all,please rate,thank you.
Jul 06, 2010 | Fedders A6Y12F2D Thru-Wall/Window Air...
AC is running continously but it is not cooling.
You mean the evaporator has no condensate? Is the condensor hot? It sounds to be in need of servicing. The temp coming out of the evaporator should be 10 to 20 degrees cooler than the air in the room which is being blown through the evaporator to be cooled. No condensation, either low humidity or no refrigerant in system. You may need to call an a/c repair. Good Luck, Ned---- The condensor is the outside unit and there should be no water coming from it and it should be blowing hot air
Aug 27, 2009 | Carrier 38BRC048 Air Conditioner
Air conditioner and heat blower
You will have two fans, one fan blows out the rear of the unit that cools the condenser soil, one blows out the front across the evaporator that blows the cold air out into the room. Some window a/c's have whats called a squirrel cage fan assy. that has one motor that runs both fans. So you either have one bad fan motor (the evap fan motor) or you have a bad fan blade that has fallen off the shaft. Also check the filter see if it is clean.
Jul 30, 2009 | Heating & Cooling
The 10,000 BTU portable room a/c unit is not running cold enough
Make sure your vent is closed. check the filter to see if its clean. If you run the a/c you can check your evaporator to see if you have condensation or does it freeze up?
Make sure you have your unit on early in the morning. If you turn it on in the afternoon the humidity might be too much and it will take along time to cool down.
Try those things if that doesnt work then you need a service call.
Jul 10, 2009 | Whirlpool ACP102PR Portable Air...
Rheem Criterion II air conditioner runs but it does not cool
Check air temp out vent should be approx 20 degrees colder than room temp if it is your unit is too small for the amount of space you are cooling.Rule of thumb 1 ton(12,000btu's) for every 400 sq ft of uninsulated space
May 30, 2009 | Amana Comfort Zone 12M32PBEH Air...
Stand alone AC blows cool air but does not cool the room
send tank capacity.model mail me mintex007@yahoo.com
Oct 09, 2007 | Heating & Cooling
Carrier 38CKC042 Air Conditioner Logo
141 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
