Question about Mitsubishi VS-50609 50" Rear Projection Television
Tv turn on sometime and run good for hours,then gose out.sometime it want tirn on at all.
  • 668 Answers
These sets have had issues with loose solder connections on the Yoke connectors at the Yoke themselves. Particularly the Horizontal
section of the connectors. Re soldering all the connectors on the Yoke could well fix it. You can gain access to them by removing the front panel. If do not have a electronic back ground I do not recommend you to attempt this, call a professional.
Hope this helps,
Skyassoc
Posted on Jun 29, 2009
Sony bravia problems....intermittent fault. Colour turns psychedelic. Looks like TV is "on acid"!! Sometimes TV can run normally for several hours before the colour fault occurs.
You have a defective T-Con board. The small board near the top center of tv. Can not give you the part number without knowing your TV model. Depending on model $50-120 for part.
Apr 16, 2014 | Televison & Video
My tv shuts off after 10 min of use and then i can turn it on and then after 10 min agin it gose off
This can be solved by going into settings and taking off a timer. or u can simply reset the tv to factory settings and go from there. If you have any other questions visit my 12 hour tech support website. http://dsc-danielsstarcompanys.blogspot.com/
click support for help. Hope this works. good luck.
Jan 15, 2012 | Samsung HL-R6167W 61" HDTV
Not starting
does the starter actually turn the engine everytime or nothing at all sometimres?if it fails to tirn ovewr sometimes, it could be the bendix in the starter, or the solonoid switch ,sometimes its in starter sometimes its under hood
Nov 12, 2011 | 2005 Saturn ION
Alba lcd32880hdf tv after a few seconds the pitcher gose off
Ive got a albe Lcd32880HDF And the picture goes off 14 months old sound only?
Jan 07, 2011 | Televison & Video
I got c180k 2004 when I am in heavy traffic the temperature gose up and show 'coolant see showroom' when the traffic easy up and start to flow the temperature goes down.I try to run the engine for a long...
possibly faulty electronic fan control module which is inside the radiator fan, must get your car in to the Mercedes workshop and read fault code and also they can activate and check is the fan is working or not by there diagnostic CPU, if the activation dos not work, then replace the radiator fan , is this information helped you?
Oct 13, 2010 | 2004 Mercedes-Benz C-Class
Run good till the check engine light go off
Check the fuel lines under the car. Don't actually start the car though, just turn the key until you hear the fuel pump turn on. This will load the fuel system and you will be able to see leaks (or sprays) under the car because of the pressure. If there are no leaks, see if the car runs perfect with a full tank of gas compared to a low tank. It should drive good turning left, but it might **** turning right or after a sudden stop. This could mean you have a crack in the seams of your gas tank or that your fuel pump is going bad (or a little of both).
Jun 07, 2010 | 1991 Honda Accord
When turn on tv in morning it gose back off so i turn it back on the green light on front sometimes blinks and then might come on
TV problems. Unplug the Cable box and vcr. Plug the tv direct into a diffrent outlet and if the sme problem comes on ...then your tv set is having problems.
Mar 18, 2010 | Philips Televison & Video
Car starts sounding like it has fuel starvation spuddering
Sounds like the vent on your gas cap is blocked.
The next time it dies, try opening the gas cap and listen for a sound like air escaping. If you hear this, it should start right back up again.
If I'm right, you just need to replace the fuel cap ($5 at any gas station or auto parts store) and you'll be good as new.
Sep 09, 2009 | 1993 Mercedes-Benz 190
Everytime i turn on my computer my monitor screen gose off and then it comes back on and it gose on like 5 to 10 times but or even sometimes it comes out like if it was burning too ,if anyone has this...
Check this monitor on a known good PC. At this point you need to determine if the PC video card is the problem or the monitor, although I suspect the monitors power supply capacitors are going bad.
Mar 28, 2009 | ViewSonic VX910 19" LCD Monitor
TV won't shut off
Sounds like color wheel BP96-00250A. Have installed by professional $350 ish
Aug 23, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Mitsubishi VS-50609 50" Rear Projection Television Logo
123 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
