SOURCE: please give me the start up directions for the
hold arrow down till beep hold arrow up till beep press up arrow to desired amount of hours then hold both arrows down till beep to lock in schedule. It will run that schedule every day.
SOURCE: saltwater pool and my pool water is green
I just posted to another similar problem and I am terrible at typing I copied and pasted this for you
So many peolpe are led to believe that using a salt system takes away the need of other chemicals
This couldn't be further from the truth A salt system just makes it so that you do not have to physicaly ad liquid chlorine or float tablets
First of all lets get a little educated in pool maintainence 101 and then I will address your problem ( First problem was buying an Intex product ) but I will cover that too
You can not just blindly ad salt to the system
you need to get a salt test kit that reads in #'s not color
You need to get the water to as close to 3000ppm as possible
Any lower than 2700ppm and you can trigger low salt alarm, not to mention not generating enough chlorine
Any higher than 3500 and you can go cloudy, trigger high salt alarm and you could go cloudy
Now for the intex curse
not a single pump/filter is sufficient with the pools they come with
They are to small
A pool needs to be turned over at least 3-4 times in a cycle 24 hours
I do not know your gl or pump size so I will use generic #'s
If you have a 5000gl pool and a 1500gl pump thats 10 1/2 hours of filtering at the minimum
Use your #'s and figure out what you need to be doing
You want to start by getting your salt right this is crucial What it says in the manuals is just a starting point the fine tuning is up to you
Lets now side track and I will tell you how to cure your problem.
This is time consuming but will give you the best results
Blast out your paper cartridge with the water hose now ad 1 gallon ofliquid chlorine
Filter only for 24 hours now brush your pool with a pool brush not the bristles under your vaccum not enough of them to do any good
now clean the filter again and run for a few hours until you see things settle down
Vaccum and clean the filter and start over again
Check your chlorine if it is normal or low ad another 1/2 if it is super high then leave the chlorine step out
Once you are clear again or close to it Ad a non foaming algecide and also ad chlorine stabilizer this is a chemical that you put in a nylon sock and float it behind the ladder this will help hold the chlorine
Once your chlorine level is at the point you can swimm again you should get your best swimmer to get in with a tooth brush and clean the over flaps in the seems that are on the bottom and where the sides connect to the floor
This should do it
lets look at one more thing
Chlorine generation
There may be night that you need to run it 12 hours for chlorine and other nights 5 or so
It all depends on many factors
sun,heat,number of swimmers, sun tan oil and so on
The biggest thing you can do wrong is to not use the pool If it is not being used every day you should brush sides and floor every 3 days or so. The pump is not strong enough to circulate the water properly
One more thing that I do and I have not changed my filters in this being my 3rd season
I have 2 one is always drying
Start with a dry filter and have the other clean and drying
Change them every couple of days.
Never try to use a wet filter it does not work like a dry one
Dont ask why it is just one of those mysteries
Also periodicaly take the hose off the front of the motor your inlet hose this can build up hair and debris that gets in from skimming
Good Luck
Don't forget to rate this
SOURCE: We have a Krystal Clear
You should always follow the instructions on the manual .. I have a 18X33X4 oval and had to start with over 350 lbs of salt and ran the pump without the chlorinator for 24 hours to properly disolve the salt. Then, I started with 12 hrs pump cycle with 10 hrs of chlorination in between the 12 hrs. Keep checking the chlorine level and adjust time from there. Currently at temperatures of 85 to 100, I run the system at 10 hrs pump with 8 hrs chrlorinator and water is Crystal Clear... In the 2 years with the intex system, I have not added any chemicals to my pool. I once had an issue when the water level went low while I was on vacation, when I came back, the chrolinator had turned off due to low flow and my pool water was green.. As soon as I re-started the cycle, a few days later, Crystal Clear again... NO CHEMICALS OR SHOCK added.... Hope this helps....
SOURCE: hi I have ab 18x52'
Get ready for a full weekend of cleaning your pool :) This is the chemical free method...
1st... Start with a clean filter...So clean your filter...
2nd.. Vacuum your pool and get most of the algae up from the bottom and sides.. Go slow so you do not stir up the algae. Make sure you use the vacuum attachment with brushes..
3rd..Clean your filter...
4th...repeat step 2 again...
5th... Clean your filter...
6th... Brush your pool with a pool brush to loosen the remaining algae..
7th... Set your pump timer for 12 hrs and your chlorinator for 10 to 11 of those hrs... and run for 3 days...
8th.. Check your water and see if has cleared and the algae is almost completely gone.. If so, check your free chlorine level and adjust your cycle down if at the required level..
9th.. if your chlorine level is not at optimal, run at the 12 hr cycle for 3 more days and check..
10th.. After water is clear and free of algae, clean your filter and adjust your cycle down to control your free chlorine level...
Good luck and hope this method works for you.. It has for me for over 2 years with my Intex Salt Water system...
Please take the time to rate me and write a comment... really appreciate!!!
SOURCE: my intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
