SOURCE: ive got a 10x10 lawn
Okay, Here it goes.
First lay out all of the parts by number (little stickers on poles) or sizes if the stickers are gone.
Take
Take the 1's and 2's and connect them together creating one big pole that will act as one of the roof peak structures. If you have lost your numbers, these two poles should be the two middle sized poles (4 of each).
Then connect each end of #1 to the center peak piece
Once all four combined poles (1 and 2) are attached to the center piece, add the pole brace pieces to each end of the bottom or #2 Piece.
Once this is done, combine two number 3's with one 4 (the 4 being in the middle of the two with both silver metal fasteners on the #3 poles facing outwards)
Then connect each end of the combined poles to the end piece.
Now lay out the final set of poles (# 5 and 6), but only connect the #5 pole to the end piece first, all around the gazebo.
Okay, now we want to start adding the actual canopy. Start by pulling the corners down at each pole joint then velcroing the tarp underneath in the middle of the 3-4-3 combined pole.
Now it is safe to connect the next set of poles (#6) to the leg poles (#5). Make sure the end with the 3 drilled holes are closest to the ground. On each end of the tarp legs there is a silver hook. Hook this into the 1st hole in the pole for support.
Connect the foot cap to the end of each pole and then connect the plastic o ring to the connector on the foot piece and readjust the silver hook as needed to either hole 2 or 3 (see photos).
Then the final parts are easy, secure any velcro straps to the legs, then use the stakes to stake down the whole thing and you may use the secure ropes as needed though I tend two just put two stakes in each foot piece at different angles.
Congratulations !!!!! Your Summer Rite Gazebo is ready for festivities. Hope this helps !!!
Sincerely Dustin R. Sponsler
SOURCE: I have a Summer Rite hexangular gazebo with screen
I need to buy the plastic replacement parts for a summer rite hex gazebo. I can't find them online
Gazebo is one of the most popular camp furniture nowadays. It is an ideal portable shelter for boating, camping, fishing and barbequing. They protect from the sun and from rain and changes in weather.
