Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
LT2000 had been working fine, but trying to start
Craftsman LT2000 tractor had been working fine, but trying to start it recently nothing whatsoever happens when I turn the key. Battery appears to be fully charged.
  • bobchalmers Jul 03, 2009
    The fuse was blown. I've replaced the fuse twice now and it blows every time I attempt to start it - something is shorted some where?
  • 999 Answers
Make sure there is no corrosion on the battery terminal connections and check the fuse and safety switches clutch, brake,seat.
Eric
Posted on Jun 29, 2009
  • Eric Duda
    Eric Duda Jul 05, 2009
    If it blows immediately it is a short. If it opens over time it is a high amp draw producing heat. Look for bad connections especially the battery terminals. Loose spade connectors are a clue as to which circuit is acting up as they will loosen when overheated also. eric
The first time this happened to me it was because the mower blades were engaged, I had left the red button up when I shut it off.
Posted on Jul 01, 2009
Craftsman tractor lt2000 with 17hp Kohler won't start. Ran fine last week. Rebuilt carb, changed oil, and new plug & fuel filter month ago. Has spark and fuel. Cranks but won't fire.
Hi Mike:
It's trying to make you crazy.
I have a model YT4000 and it is a PITA to start when cold.
I pull the air filter, toss in a bit of gas to prime it, and it starts instantly.
I'd suggest that you give yours another try. 3 or 4 times of a couple of seconds each. If it doesn't go, pull a spark plug and see if it is wet or dry. Wet indicates getting gas but no spark. Dry indicates not getting gas.
While you have the plug out, check the spark... Hot & blue.
Hope this gives you some more to work with.
Jun 22, 2015 | Craftsman Garden
Need free owners manual for a 6 speed craftsman Lt 20000 17.5 HP riding mower
You normally download the Craftsman manuals @
http://www.searspartsdirect.com/
You will the model number from the serial number decal under the seat area. This number usually starts with 917.
Aug 05, 2014 | Craftsman Garden
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
How do I get my craftsman lt2000 to not die?
safety switches need to be replaced
Jun 13, 2013 | Garden
Craftsman lt2000 will not start
You should read 12 volts atleast. Try www.managemylife.com for a owner's manual.
May 08, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman LT2000 tractor seems to drain batteries over a 3 t 4 month period. Works fine then it just dies after 3 or 4 months and battery is shot?
Check your charging system! The alternator may be bad. If you can't get it repaired, just put a trickle charger on the battery the night before use. That is not a fix but will get you by...Lee
May 28, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cratsman lt2000 lawn tractor will start but will not move forward or backward. I tried changing the drive belt, but that didn't work.
Is the transaxle pulley turning? If so have you removed the rear wheel recently and possibly lost the square key that fits on the axle?check those two items first.If ok it probably has a broken gear or shift key in transaxle.
Jul 14, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,036 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
