Question about Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed
My pump whines very loud while running? Any
My pump whines very loud while running? Any troubleshooting ideas?
  • 4 Answers
Check the motor bearings,(take the pump apart from the motoer should 4 bolt,,,, then wiggle the shaft should not move at all.) then look at the impeller to see how worn it is or if it is touching any part of the houseing.
Posted on Jun 29, 2009
What is causing a whining noise
if the pumps aren't adjust correctly they will whine when the brake is set. if they whine all the time or low on power they might be getting bad. it's called cavitation.
Nov 29, 2017 | Garden
Whinning noise when engine is off
Whinning Causes
The whining noise you hear coming from the power steering pump is one of three things. The first is more of a loud "hush" than a whine; this is the sound of fluid rushing through the bypass valve when you turn the wheel all the way to one side or the other. Sometimes the bypass valve malfunctions or doesn't open all the way, causing pressure to back up in the pump and cause your engine rpm to drop. The second and third causes result from cavitation -- vacuum pockets created behind the rotor's vane blades as a result of extremely high pump action -- or air in the lines.
Nov 24, 2013 | 2003 Mini Cooper
93 s10 whines
The fuel pressure regulator & spyder assy, most likely is bad
Don't think that is your noise though
Check trans fluid,may be pump noise
Jan 06, 2013 | 1993 Chevrolet S-10
There is a loud "whining"
Power steering pumps whine when they are low on fluid, or if they are goin bad. Serpentine belts also whine in cold weather or when they are goin bad. Tru spraying just a little WD40 on the belts when its running, if it goes away, you should be thinking about a new belt. If nothing changes, check the power steering fluid, if its full, take to a mechanic
Mar 01, 2011 | 2004 Cadillac SRX
Pump is whining and making very loud noise.
Install air vent?
Clean pump impeller with white vinegar?
replace pump?
Troubleshoot resources:
http://waterheatertimer.org/Water-heater-recirculation-system.html
Gene
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 27, 2010 | Grundfos Comfort System Recirculator ...
When running it makes a loud noise
Your bearing are failing. Replacing them and the seal at a local electric motor repair shop will likely cost around $50.
Jun 02, 2009 | Polaris Pb460 Polaris Booster Pump...
Loud whining noise
check alternator bearings for noise
Apr 09, 2009 | 1999 Dodge Intrepid
Whining coming from rear near fuel tank.
fuel pump,some are inside the tank some are not.If its outside the tank it should be quite easy to fix.
Mar 07, 2009 | 1988 Isuzu Trooper 2 Door
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Aqua Flo Aquaflo Flo Master Xp2 Spa Pump 1.5 Hp Two Speed  Logo
650 people viewed this question
Top Aqua Flo Pool & Spa Experts
Jay Finke
Jay Finke
Gene Haynes
David Spradling
David Spradling
Are you an Aqua Flo Pool and Spa Expert? Answer questions, earn points and help others
