Question about Amana ALG331RAW Gas Dryer
New Dryer Belt
I replaced my GE dryer belt. Everything seems to be fine but when I start the dryer it does not spin once I release the start button.If I hold the start button in place it spins and heats.Any suggestions?
  • 248 Answers
The switch on motor is sticking or broke. You can try cleaning lint from motor and around switch. (Box with wires going to it on motor.) If this doesn't work you probably need a motor.l
Posted on Nov 08, 2007
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
I have a ge model# gtdx100emoww electric dryer that will only work if the start button is held in. Once released it stops.
Yep, it's the start/run switch at the motor, can get stuck with lint after a long time. It's actually not too difficult to change, make sure you note the location of every wire. Clean everything real good with a vacuum cleaner, get all the lint dust out of the motor, etc.
Cleaning may free the switch, and there should be a drawing showing how to put the belt back on, otherwise, make a drawing.
Nov 22, 2013 | Kenmore Elite HE4 Electric Dryer
I HAVE A GE DRYER THE MOTOR SHUTS OFF WHEN YOU RELEASE THE START BUTTON AND THE DRUNM WONT ROTATE
there's a broken belt switch connected to the belt idler pulley,(when this belt breaks the switch opens) located down by the motor and it kills the power to the dryer when the belt breaks so the heating element cant get the clothes too hot to burn the clothes when the drum cannot rotate properly
Feb 25, 2012 | General Electric Dryers
Kenmore 600 Dryer- suddenly stopped working
can you hear the motor running, if so then more than likely the belt broke, you need to unplug it ,remove the front cover, then top cover, then remove drum and you can start to restring the new belt
Oct 26, 2009 | Kenmore 600 7962 Dryer
Whirlpool dryer will not spin
Since your dryer is "new" it is under warranty. I will explain the possible reasons why it will not spin. Then you can decide whether to make the warranty call or not.
If your dryer doesn't tumble, check these:
Belt
Motor
Door switch
Belt Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
Motor If the dryer motor only hums when you press the Start button, the motor may be burned out. Here's how to test the dryer motor:
  • Remove the belt.
  • Check for obstructions in the blower fan housing.
  • Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor.
If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers or pulley, and then reassemble the dryer and try it again.
If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor.
Door switch Your dryer can't operate at all if the door switch is defective. It's inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. If it's defective, you need to replace it.
May 21, 2009 | Dryers
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
Mar 21, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer won't run right
The motor in your unit has to be replaced. The centrifical sw can't seem to keep the motor going. The shaft may spin freely, but once power is present the shaft locks up therefore your over amping the motor and it then trips the breaker. Since you already had the unit apart you will do fine replacing the motor. Good luck
dmparenti
Dec 29, 2008 | Maytag PYE2300AY Electric Dryer
The drum of my Kenmore 80 series electric dryer is not turning
sounds like you need a new drum belt. start by taking the top off then the front panel will have screws inside for removing the front. then once the front is off you will see the motor and where the belt should be. if the belt is broken, replace it, if not just put it back on the motor and idler pulley.
Dec 28, 2008 | Kenmore 659 Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Amana ALG331RAW Gas Dryer Logo
81 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
