Question about Troy-Bilt Pony Garden Tiller
My troy built keeps eating the forward drive belt?
  • 376 Answers
Had one do that not long ago. The problem was the idler pulley that pushes against the belt when you pull the engage lever on the handle was not lined up with the belt. I just bent the idler bracket to line up the pulley with the belt. Maybe this will help, assuming you have the same model.
Posted on Jun 29, 2009
Troy built 42in cut wont move forward or reverse . smells like rubber burning , could the belt be slipping ?
If you smell rubber... replace the belt and make sure ALL pullies are turning free.
Jul 01, 2017 | Troy Garden
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy built lawn mower (riding) won't go full
I did not know riding mower had a gas pedal. I know if you leave the throttle control up all the way the engine will choke out. The pedal you are pushing, I think, is the forward/reverse hydrostatic transmission. You may need a new drive belt. The one you have now may be stretched out.
Good Day.
Oct 07, 2009 | Troy Garden
I have a troy-built rear blade tiller. It starts fine but when the blades hit the ground they stop turning.
Your belt is likely slipping. To adjust the belts, slide the block down that the roller on the forward/reverse lever uses to lock the tiller into forward. Use a 9/16" wrench to loosen the bolt on the backside of the block, then slide the block down a bit and retighten the bolt. If it's not the belt slipping, you've got transmission gear or bearing problems that could be costly to repair. I hope it's the simple adjustment.
Jun 15, 2009 | Troy-Bilt Garden
Changing Drive belt On Troy Built Tiller
You have to remove the engine (4 bolts, no big problem), then remove the bolt in the center of the pulleys, then remove the pulleys. Slip the belt(s) (2 if you have the Super Bronco model) onto the pulleys, re-attach the pulleys with the bolt, re-mount the engine, and you're home free.
May 20, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt Pony Garden Tiller Logo
631 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
