Question about Kenmore Refrigerators
I have a Kenmore model `06.51552104 Refrigerator and the ice make quit producing ice. When I open the door the red light flashes twice, then pause, then flashes twice etc. Does this code mean anything? What can I do to get the ice maker working? MJ
  • 999 Answers
Look behind the grill on the bottom for the tech sheet. It will tell you what the flash means and provide a diagnostic sequence to test it out.
Eric
Posted on Jun 29, 2009
Ice maker will not make ice. everything in installed properly. unit is 7 years old. red light flashes twice, then pauses and flashes twice again.
in the door ice storage. this is complicated. might check at the bottom of ref. there is a removable toe panel and on the back of the toe panel usually there is wiring diagram & mini manual to help diagnose icemaker problems.
Jan 03, 2010 | KitchenAid KSSS36QK Side by Side...
Icemaker not working- red light flashes constantly
The red light should flash twice , pause then flash twice constantly . If you close the flap on the left side , then the light should go off . This shows the optics (ice maker cut off ) are good .
Check the black tube ( fill tube ) , which puts water into the ice maker , to see if it is iced inside . If so , then the water valve behind the refrig is bad . It seeps into the tube and freezes , blocking the water flow .
Pour about 2/3 cup of water into the ice maker . If it freezes and dumps , then the water valve needs replaced . If it doesn't dump , and stays frozen in the ice maker , replace the ice maker . Also , make sure the coils under the front of the refrig are clean , as this will cause warmer temp in the freezer and the ice maker needs 5 degrees to operate .
Sep 27, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool side by side Ice maker has quite making ice
Open the freezer door and on the right side , make dure the slide is in the on position . If the red light flashes twice , then pauses , flashes twice , pauses , consistently , then close the flap door on the left side of the freezer . The light should go off . If these tests work , then the cut-off optics are good , and the icemaker needs replaced , due to the cubes not dumping . Also check the coils under the front of the refrig , to make sure they are clean of dust , lint , etc.
Sep 15, 2009 | Whirlpool GS6NBEXR Side by Side...
KitchenAid Fridge, Ice maker not working - red light blinking
Replace the icemaker . The laser receiver (on right side ) is supposed to blink twice then pause then twice repeatedly .Normal. Also clean the coils under fridge .
Aug 02, 2009 | KitchenAid KSCS25FKSS Side by Side...
Ice maker broken
first if you take off that panel there is a circuit board . unlpug the board and put it back to gether if that dont work then replace it... i sometimes get away with both! i can also get you that part pretty cheap... here is my site. grab the number and give me a call thanks.
Apr 30, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Not making ice flashing light in freezer door 106.53659300
There is a board for sale on eBay for $68.00.
This is a relatively easy procedure. Just have to buy the board
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Optical sensor or valve problem
Your ice maker has an automatic shutoff. The ice maker sensor passes a beam from one freezer wall to the other, automatically stopping ice production when the storage bin is full. When you open the freezer door, you should see a red light on the top right freezer wall.When the freezer door is open or the ice storage bin is removed, the sensor cover or "flipper door" on the left wall of the freezer stops the ice maker from producing ice by blocking this sensor, When the beam is blocked, the red light on the right will blink twice. This is normal operation. as for the blink twice and pause I'm still checking on that. Make sure the water flow is coming from the solenoid valve located on back and bottom of refrigerator to the ice maker. Check the solenoid to see if the magnetic field is pulling the internal plunger open when ice maker ask for water. That can be checked with a multi meter at the wireing going to the solenoid and if the ice optics are telling the tray to fill voltage should be present. Insure that water supply is not restricted before it comes to the solenoid , like a bent line or clogged piercing valve.  Check that an ice cube is not jammed in the ejector arm of the ice maker. Remove jammed ice from the ejector arm using only a plastic utensil so the ice maker is not damaged. Call toll free in USA and a trained consultant will be happy to assist you. 1-866-698-2538
Oct 22, 2007 | Whirlpool GC5SHEXN Side by Side...
Ice maker repair and still no ice
Amyc, of course you should call this cat back, but here are a few things to check. Make sure that the fill tube is not frozen over. The black tube feeding water to the IM. Next with the freezer door open your optics should flash twice with a pause repeatedly. Hold the left side emitter flap down and the light should be on steady. If this checks, the optics are good. The ice maker rakes should be at the 2:00 position when it's in it's home positon. Any other position could be a bad module. When the cat comes back to check it out, make sure he jumps the ice-maker to get the unit to fill before he leaves...Catriver..post back.
Mar 02, 2007 | Kenmore 53582 / 53584 Side by Side...
Refrigerators Logo
98 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
