Question about Refrigerators
I have a kenmore Ref. Model #106-59028991 side by side. how do you replace the studs & screws that holds the crisper draws on the right side?
  • 999 Answers
The studs twist counterclockwise to remove.
Eric
Posted on Jun 29, 2009
I would like to replace the handle of a crisper drawer on kenmore 795.77309600
I think you are referring to the large button that breaks in the front of the two bottom crisper bins? They are not identical with one being slightly larger so you need to know which side. You can go to sears parts . com and put your model in to see a drawing of it and pick the one you need. They list for 110$ and 122$ but you might be able to find them cheaper on another site. The fridge is made by lg for Kenmore so it might say LG or Kenmore when looking at/buying parts.
Jan 23, 2018 | Kenmore Refrigerators
Bottom refrigerator crisper drawer slide fell off
draw slide is mounted to the shelf bracket --either order new bracket or remove bracket [look how slide positioned on other side ] and try drilling and putting in small screw and nuts till you can order a replacement bracket
Sep 09, 2016 | Refrigerators
I need a right hand crisper draw for a Samsung refridgerator model srf680cdls
Hello Kate Nicholas,
Your model srf680cdls... does not respond domestically in the USA... If you provide your ACTUAL PART NUMBER I could attempt to check CRISPER availability ... here (you appear to have an "AU" model.
Just looking around the large plastic body would appear to cost about $60 (USA)... I'm pretty sure we share the MANY of the same internal part numbers..
http://www.woolleys.com.au/?gclid=CPqQzujj184CFQYdaQod1n0AIw
BigWarehouse Spare Parts samsung crisper drawer
Sydney Only Samsung SRF680CDLS 680L French Door Fridge with Water and Ice...
http://www.ebay.com.au/itm/ws/eBayISAPI.dll?ViewItem&item=121998338668&catId=20710&item=121998338668&mid=503315&sdc_id=1081525136346&sortbid=15&rmvSB=true
Samsung 28 15 cu ft 4 Door French Door Refrigerator in Stainless Steel...
http://www.appliancepartspros.com/samsung-case-veg-assy-da97-08437d-ap5805507.html
Aug 23, 2016 | Samsung Refrigerators
How can I pull drawer out so I can clean under kenmore HE4
there are two screws on the in side of the draw that hold the draw to a metal track..take them out and it should slid right off
Oct 01, 2013 | Kenmore Elite HE4 Electric Dryer
Where do I find the model number? the crisper door is broken. I need a replacement for a superba 42 refrigerator.
The model number is most likely located in the ref. up on the inside wall, usually to left but sometime on the right hand side.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Nov 07, 2010 | KitchenAid Refrigerators
I have a Kenmore side by side 26' model 596.50692000. The unit is cooling however, the lights in the freezer side and the dispenser for ice & water outside the lights do not work but the water...
in the past i have seen this happen when the ice ben is emoved and the drive impeller is not seated properly usually due to ice ect. Its a pain but take out the ben and see if the motor turns normally. you can hold the door switch closed by hand and have someone push the button for ice if the motor turns you have the problem i have said. If not your door switch is bad and needs to be replaced it controlls the power to the bulb and the ice maker motor. You can pop the door switch out with a flatblade screw driver but have a replacement on hand wire plug into the back of it the switch is an on off switch. Make sure you unplug the ref first electricity bites...
Aug 08, 2010 | Kenmore Refrigerators
I have a craftsman chainsaw that I have snapped off 1 of the studs that hold the chain bar no.Problem is I cant work out how to remove the snapped stud. Are they screwed in or pressed in? how do I get them...
Go to: www.Searspartsdirect.com and enter the complete model number minus the decimal point. This will take you to a series of replacement part drawings. Check the drawing for the stud and see if it has a square head which would imply that it is replaceable from behind the bar bracket. Hope this helps!
Jun 18, 2010 | Garden
Broken crisper roller tracks on KitchenAid frdge md# KBRS22KFWHO
fixya doesnt sell products or replacement parts search on line using make and model for part or notify manufacturer for a parts distributor in your area
May 18, 2017 | Frigidaire FRS3R5EMB Side by Side...
Broken refrigerator drawer support pin
I have a Kenmore 2 door,freezer on bottom, mod# 795.77309600,the shelf that holds the crisper draws cracks,front & back corners, also the back,middle. this is the 2nd time for me. Is there a solution??
Nov 24, 2008 | Refrigerators
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
