Question about Samsung HLP4663W 46" Rear Projection HDTV
No picture on a Samsung HL-P4663W, trouble lights confusing...
When I turn the power on the Lamp light blinks indicating the lamp will light in 15 seconds. However, instead of the lamp lighting the StandBy/Temp light comes on. The TV cycle through this sequence over and over. Checked the "CPU sized fan" and it is running. Held the lamp door microswitch too. The problem continues. Suggestions?
  • 668 Answers
The most common blink code for the Standby/Temp LED is the Temp Sensor and or Actuator Board. You can confirm which on by jumping the CN106 connector on the Actuator board. If the set works now, the Temp Sensor must be replaced. If it doesn't work, the Actuator Board would need to be replaced. If you are not familiar with the chassis or electronics at all , I do not recommend trying to fix it, call a professional. Don't take the chance of damaging it further.
I hope this helps,
Skyassoc
Posted on Jun 29, 2009
I can hear the movie but do not get a picture but the lamp light is blinking
Ur tv Projection lamp is dead.Ur tv Projection lamp,require replacing.The "LAMP"LED light indication blinking flashes or stay on.The projection lamp must be replaced,tries websites like Tvrepairworld.com,Partstore.com,Ebay.com to buy a new projection lamp.
Aug 04, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
I have a SAMSUNG 46" DLP HL-P4663w, No picture but have sound. All three lights are flashing at on/off button. Installed new lamp ( BP96-00826A ) still no light. There is a loud humming sound.
Hi:
This is and indication of a bad color wheel assembly, you can replace the color wheel yourself, there are lots of Youtubes videos on how to do this.
Jun 12, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Tv comes on and picture and audio go out in about 5 minutes lights blinks lamp timer Could it be lamp or balast and can both me changed by owner
Hello: This is an indication of a bad of faulty lamp. If it has been at least two years since you have purchased the unit, then replace the lamp, first as this is main fault of DLP Televisions.
Dec 04, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Shuts on and off constantly. Lanp light blinking. Sound but no picture.
I would suggest if you haven't done so alreay is replace the projection lamp. The symptom you are describing indicates a failing lamp. The lamp part number will be located on a orange and white sticker on the side and it will say LAMP CODE and will start with a number of BP96-. If the sticker is missing then you will have to remove the lamp from the TV and get the number off of the cage of it. Please take a moment to rate my answer. Thanks....
Nov 21, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Replaced lamp, still does not turn on.
LAMP #BP96-00826A
IF THE TV STAYS ON FOR 30 SECONDS IT MAY BE AN INDICATOR OF A POSSIBLE POSITIONING ISSUE WITH THE LAMP DOOR SWITCH (LITTLE BLUE SWITCH AT LOWER LEFT OF CABINET WHEN LAMP DOOR IS REMOVED.) THIS SWITCH IS SUPPOSE TO BE IN THE DOWN POSITION ONCE THE LAMP DOOR IS SECURED AND HAS CAUSED CONFUSION BEFORE.
HOPE THIS HELPS
Jul 06, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP4663W 46" Rear Projection HDTV Logo
526 people viewed this question
Jerry Greenberg
Jerry Greenberg
