Question about Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746
The blade is broken off, exactly flush with the end of the cylinder that holds it. I've tried digging it out, grab the end with pliers, and also hammered nails in the slot behind the blade to push it out.... no luck.
  • 2,176 Answers
Do you have an old blade that you can cut down to slide in behind it and try tapping on that, also you didn't say what kind of blade lock this has, I just had one that dimpled the blade so I couldn't remove and had to take a small punch and knock the dimple back and it basically fell out. Let me know if i can be of more assistance
Posted on Jul 02, 2009
How can I get a broken blade out of my zaw zaw?
Remove power or battery. If the guard is removable, take it off. Use a pair of pliers to grab the end and hit the release lever. If the blade is too short, advance the motor by moving the blades with a screw driver until the reciprocation advances the blade to you. If it's shorter than that, check for screws holding the case.
Sep 30, 2014 | Saws
Remove broken key from egnition
Hi
Use needle-nose pliers to pull the broken key out, if there is enough of it sticking out of the ignition to grab. Put a little melted wax, Museum Putty or Super Glue on the pliers before you grab the key.
Make sure that the ignition is in the "neutral" position so that the tumblers are not gripping the key. If it is in the locked position, insert a thin hacksaw blade--with the teeth facing up--next to the broken key, and turn the ignition to the "neutral" position.
Pull gently up on the hacksaw blade. If you are lucky, the teeth will grab the key and slide it out. Try this with the hacksaw blade behind the key, and again on top of the key. Most keys have a groove on them that the hacksaw blade can grab, so wiggle and twist the hacksaw blade around and see if you can feel it catch the key.
Try using the hacksaw blade and the pliers together--pushing with the blade and pulling with the pliers.
Cut or break a six- to eight-inch piece off of a wire coat hanger and use your pliers to fashion a small hook at the end. Slide this into the ignition behind the key and try to grab it. If that doesn't work, insert the wire in front of the key and try again.
Spray a little cooking spray or WD-40 into the ignition and try again with the hacksaw blade. Remember to try both in front of and behind the key, and to wiggle the blade. Do not spray the lubricant before trying the pliers or wire, because now your key is not only stuck, it is slippery.
Call a locksmith if the above steps do not work. Do it before you get too frustrated, because it is much cheaper to replace a key than it is to replace a key and a shattered ignition.
Also check this useful link:-
http://www.diylife.com/2010/06/24/the-daily-fix-remove-a-broken-key-from-a-lock/
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 23, 2012 | 2002 Kia Spectra
I have a sears reciprocating saw with a broken blade.I can't remove the busted blade.Is there any way of removing it?
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 19, 2010 | Craftsman Saws
Reciprocating saw problems cannot get broken blade out of chuck
heatman101
Aug 15, 2010 | Dewalt Saws
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Blade stuck in keyless chuck on sawzall. pin or spring must be broken. Any suggestions on how to get the blade out
heatman101
Jul 14, 2010 | Milwaukee 6520 21 12 Amp Orbital Sawzall...
Blade not releasing
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Cannot get the blade out of the porter cable reciprocating saw
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Can not replace blade on Dewalt 303 6.5amp
heatman101
May 23, 2010 | Dewalt DW303 Heavy Duty 65 Amp...
VULCAN RECIPRCTING SAW
heatman101
Jan 08, 2009 | Vulcan Pwt 18V Rs 18V Cordless...
Porter Cable Variable Speed Quik Change Tiger Saw Kit 9746 Logo
371 people viewed this question
Top Porter Cable Saws Experts
Marvin
Marvin
Frank Mangiapane
Level 1 Expert
Jim Thurston
Are you a Porter Cable Saw Expert? Answer questions, earn points and help others
