Question about Kenmore Dishwashers
Where is water filter on my Kenmore dishwasher
Where is the water filter on my Kenmore dishwasher? The incoming water is not coming out. I think the water filter needs to be cleaned/replaced
5 Suggested Answers
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
  • 9 Answers
SOURCE: Where is the filter on a Kenmore Quiet Guard 2 dishwasher?
I have a Quiet Guard 4. Same problem so will describe my solution.
1. Remove bottom basket. Remove top basket.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly up and out.
3. Remove overhead conduit. One screw at back, one at top (Philips #2 bit). Rotate whole assembly 45 deg right (Clockwise) and lift off of centre post.
4. Remove centre post (Pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off screen and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (under assembly removed in 4). Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter and filter. It is on a spring loaded pin. Pull the cutter blade foreward and then the filter disc straight up. Clean thoroughly as it may be the cause of your problems.
Reassimble. Good luck!
Posted on Jan 02, 2009
garing
  • 998 Answers
SOURCE: Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Posted on Aug 11, 2009
SOURCE: dishwasher not cleaning - want to clean drain
We have a Kenmore 665.17702k600 Portable dishwasher with a similar problem. What we did was pop off the drain cover (turns out the one screw wasn't doing anything and just pushed down into the unit when screwdriver was applied). We popped it off by shimmying a screwdriver under the panel, and applying torque on the long end. It just popped right off. Then there was this nasty stale water, and not much obvious debri. We used a wet vac to slurp all that up. So that's the solution we took -- haven't tried it yet, so not sure if it will actually fix the problem...
Posted on Jan 23, 2010
KENMORE ELITE DISHWASHER MODEL 665.12793K311 STOPS BECAUSE THERE IS NOT ENOUGH INCOMING WATER, IS THERE A CLOGGED FILTER
Check the shutoff vale under the sink where your dishwasher water line is connected to ensure it is full open. Also, check for a kinked water line to the dishwasher.
Sep 06, 2017 | Kenmore Dishwashers
I have a Miele g7856 and I just replaced the drain hose now I get a F2E code ?
The F 2E code indicates insufficient water coming into the dishwasher. Thus you should check that the shut-off valves for the incoming water lines are open. Make sure that the incoming water pressure hasn't decreased and that the water lines aren't kinked or blocked. You should also check the water inlet filters (at the screw connection of the hose) and the flow restrictor insert in the waterproof system.
Since the dishwasher was working before the drain hose was replaced, closed shut-off valves and kinked hoses are particularly likely. You may also want to replace the inlet hoses themselves. (Some anti-burst hoses will restrict the water flow if they detect a leak.)
I hope this helps.
Oct 19, 2016 | Miele Dishwashers
Does this dishwasher Kenmore 13543 raise the water temp so the soap cleans correctly? We have hard water and even the best soap leaves a white film even adding rinse aide in my old BROKEN machine.
there is not much you can do with hard water as it is the minerals in the water that cause the problem
it is cheaper to let the washer heat the water as it only heats what it wants
Hard water comes from bores as most town water is put through osmosis filters that remove the minerals and produce the soft water
If you have a bore supply the seriously consider fitting a osmosis filter before the house as it will fix all sorts of problems found in the shower, hot water system , septic/sewerage and general health of the people in the house.
The initial cost will be outweighed by the cost savings from detergents and heating
Apr 07, 2015 | Dishwashers
Float in dishwasher not recognizing water level
Hi. The float sensor is just a fail safe device to prevent the DW from overflowing. I would first check the incoming water pressure and also check the input water valve to make sure that the screen is not clogged. Try running it without the water pre-heat feature also. BTW, it should be connected to the Hot water line.Temp. sensors will cause erratic problems in this case. Hope this helps.
Sep 29, 2017 | Kenmore 24 in. Elite Built-In Dishwasher...
Light flashes 7 times then pauses and blinks 7 times again, and keeps repeating
Temperature problem with water. Incoming water when filled should be no less then 1/2 inch below heater. If not, possible water valve. Incoming water temp. min after fill. 120 degrees. Missaligned door. One of door switches not activating. Bad circulation motor. Not throwing water over heater. Tech.sheet behind bottom panel. Will tell you. Shorted heater. When bottom panel is removed. Look for signs of water leaks. Hard water deposits on floor.
Mar 28, 2011 | Kenmore 24 in. 17032 Built-in Dishwasher
Kenmore Model 16798 dishwasher: no incoming water throughout entire cycle
Hello there
The solenoid is just a valve. Only it operates electrically.
Check to be sure you are getting water to the valve. Turn off water,
disconnect water supply from solenoid valve, place line in bucket, turn on
water slowly.
Does water come out?
If yes, then reconnect water and check other side of valve. Disconnect
connection on other side of solenoid valve. Does water come out when you
cycle dishwasher?
Could be a problem with plugged water tubes. All sorts of junk comes out of
water lines.
Also if you have a manual valve on the wall for line going to dishwasher,
the line could be plugged at this valve. Turning it off/on several times or
backflushing might clear the plug.
Mar 04, 2011 | Kenmore Dishwashers
My dishwasher won't fill with water
There can only be these reasons:
1 Water valve shut off
2 Door not locked in
3 water relay/solenoid valve broke or inoperable
4 Plastic lines kinked for supply
5 Filter for water clogged.
I'm thinking number 3 or number 5 Hope this at least gives you some things to look at.
Jan 08, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Water doesn't come out of spray bar. water fills dishwasher (and can drain), it also gets heated. But the spray bars won't spray any water (top or bottom). Any ideas?
There is a pump that sends the water to the spray bars. I believe it is broken. Perhaps there is a jam but I don't think it is possible because the water is filtered before going to the pump.
Anyway. The pump may need to be replaced (not the drain pump).
Sep 01, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash dishwasher
check and see if you are getting ac 110 volts to your water vave when trying to start the unit. if no power check your breakers and /or the incoming power to your dishwasher if they are ok and show 110 voltage coming to the unit then you probably have a control board or touchpad problem which would need a little more detailed check out.
If you do have ac 110 to your water valve then you may just have a bad water valve. Because the washer has to fill first. Hope that helps!!
Jun 29, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Frigidaire D/W. Model fd8750rcc0
hi Dishwashers usually run on 115-volt or 120-volt power. The water they use comes directly from the water heater, and wastewater is drained into the sink's drainpipe. The dishwasher is not connected to the cold-water supply. For best dishwashing results, set the temperature control of the water heater to no less than 140 degrees Farenheit. Water cooler than this usually doesn't get the dishes clean, unless your dishwasher is a newer model that preheats incoming water. The water shutoff for the dishwasher is typically located below the adjoining sink.
Nov 06, 2008 | Zanussi 24 in. DA6153 Free-standing...
Dishwashers Logo
254 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
