Question about HP Officejet 7210 All-In-One InkJet Printer
My Hp Officejet 7210 will not scan,fax or feed from the ADF. It prints fine from the computer, but I copy from the glass I cannot do multiple copies. Please help. Thanks.
  • realtrgrl200 Jun 29, 2009
    Thank you. I've cleaned the rollers. The error I get is scanner failure, cycle power and try again. So I have to cycle power for each copy from the glass or ADF. When using the ADF the document feeds only half way before the error occurs.
  • 23 Answers
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from our computers.
It would either grab several pages at once, or not grab paper at all. The feeder was trying but had poor traction action. Not sure if that's the same situation for you, but this is what fixed ours:
I purchased part number C7309-60091 feed roller assembly, and part number C7309-60076 separation pad from Encompass Parts, and replaced them. The ADF works great now.
Our HP Officejet 7210 had only 3,000 pages printed on it, which didn't seem like enough to wear out the separation pad or feed roller in the ADF, especially since all those pages didn't go through the ADF, so I figure it's because of our very dry environment. Hope this helps you.
Posted on Jul 15, 2009
  • 27 Answers
It may be the rollers on the adf depends on what happens when you try to copy
Posted on Jun 29, 2009
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
Paper does not feed from top of my hp 7210 printer and can not fax from top feeder. I can not use the top feeder to copy multiple documents. Only bottom feeder works. When I have to fax something, I have...
The rollers on the feeder can go bad and the best way to solve it is to get a new complete assembly. Check the website under your make and model for the assembly. YOu might also want to check for paper jam
Mar 19, 2011 | HP Officejet 7210 All-In-One InkJet...
HP OfficeJet 8500 ADF detects load, but does not detect feed. I have a brand new HP OfficeJet 8500. The ADF detects a document is loaded when I stick a piece of paper in it to be copied/scanned/faxed, but...
Remember that if you start to fiddle you void your guarantee, I know its a pain, but if I were you repack and either contact customer services and obtain a return invoice number if purchased over the internet and return to sellers. If purchased from a shop, return with your prove of purchase.
Mar 19, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I have an Officejet 5510 all-in-one printer/scanner/fax. When do a manual print (laying paper face down on glass), it works fine. When I use the automatic feed the copies have black lines along the entire...
You need to inspect and clean the narrow glass and the white reference bar that sits above the narrow glass. Scratches, whiteout, and debris will cause the lines on scanned documents.
Dec 24, 2009 | HP Officejet 5510 All-In-One Thermal...
Paper is not feeding into the top.
I also was not able to copy, scan or fax multiple pages through the ADF of our HP Officejet 7210 AIO, but it would print well from the computer.
It would either grab several pages at once, or not grab paper at all. The device was trying to work but had poor traction action. Not sure if that's the same issue you are facing, but if it is, this is what fixed my 7210: I purchased part number C7309-60091 which is the feed roller assembly, and part number C7309-60076 which is the separation pad from Encompass Parts, and replaced them. The ADF works great now. The HP Officejet 7210 had only 5,000 pages printed on it, so I chalked it up to our very dry atmosphere here.
Jul 10, 2009 | HP Officejet 7210 All-In-One InkJet...
7210 can't fax or scan
Soft/firmware issues. Try updating.
Jul 29, 2017 | HP Officejet 7210 All-In-One InkJet...
Copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
Hello, I have an HP OfficeJet 7310 all-in-one print/scanner/fax etc. I purchased about two years ago but don't use very often. Yesterday while I was trying to send a fax I received a loud winding-up...
I have same problem! The copy/scan function would feed the orginal from the ADF halfway and instead of making a normal loud feeding noise it made a horriable alarming sound and displayed an error message. To fix it: I waited a day or two and bang the top of the feeder cover with normal force while the original is feeding. It appeared the problem is resolved. I have no idea what the problem is, however I think if this work for few months at a time is fine by me.
Apr 12, 2008 | Office Equipment & Supplies
HP Officejet 7210 All-In-One InkJet Printer Logo
926 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
