Question about Maytag Neptune MDE4000 Electric Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
  • 10,865 Answers
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Posted on Jul 02, 2009
Maytag Neptune Dryer Not Drying Well, Leaves Brown Marks on Clothing. Seems like there may be multiple problems. Suggestions?
Sounds to me like an air-flow problem. Poor air-flow means dryer gets hot and scorches clothes but there is nowhere for the wet air to go, so it doesn't dry well. Check for lint-clogged ducting from the back of the dryer to the outside (or at least check both ends of the duct). Also check for a collapsed or clogged flexible tube that goes from the dryer to the duct work.
An over-heated dryer could also have warped the (usually) plastic lint filter.
Jan 07, 2015 | Maytag Dryers
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
I have a Maytag Neptune gas dryer and recently light colored clothes are coming out with small black marks on them; it looks like grease/oil stains. Where could this be coming from?
my first guess would be something ,someone placed in dryer perhaps coveralls or oily clothing.There is no place that I am aware of on a dryer where you could pick up oil leaks from ..are you sure you did not have a lint fire,the oil stains may be soot
Dec 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune running very hot, even on lowest heat setting
your cycling switch or hi-limit switch is defective they are near the heating element inside the dryer
Sep 01, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Brown spots on clothes from my maytag neptune
this sounds very much like that the bearings have badly worn-out,pain to replace them ?
Jul 13, 2009 | Washing Machines
The dryer is leaving what looks like brown burn marks on clothes
you might need to replace the felt on the inside front that the tub rides on
Apr 23, 2009 | Dryers
Clothes burnt?
Try turning down the heat setting on your dryer. This should help immensely. Dry these types of clothing on say "medium" setting and the heavier things on normal heat.
Jan 14, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer leaving brown burned lines on clothing
the rear drum seal was bad and as things rub against it they will get black marks on them.
Larry
Aug 02, 2008 | Whirlpool GEW9250P Electric Dryer
Mdg4000 GAS
bad rollers could be making black dust but the real problem is the tumblers seals letting the roller dust get into the tumblers and on to you clothes.
Black or brown makers are from the faulty or damaged tumblers seals you have one in the frount and one back...
I can help you strp by step if you want to do it yourself.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE4000 Electric Dryer Logo
438 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
