Question about Soundstream VGA400.2 Car Audio Amplifier
Soundstream ribcom500 i got this amp off of one of my friends was her sons amp an her so died in a car accident an it sat in his car for 5 years an she gave it to me to get repaired .....i took it to a local repair shop an they couldnt find out what was wrong with it ....i know about amps an have repaired them but i dont know where to start on this amp ...all the parts read fine but the amp doesnt work at all !!!! i dont know where to start..mybe the pulse width modulator ?????? i dont know .....anyone know what i sould do???
  • 39 Answers
Re: soundstream ribcom500
they should be able to help and have all the spare parts.
Posted on Jul 08, 2009
0 characters
3 Points
I've had two soundstream rubicon 1.1600D amp's and they both worked for a while then the amp started to kick off and on. No fuses were blown, and the ground was fine. Any suggestions would be appreciated.
Sounds like a loose power connection? Check All connections, also make sure the impedance is correct 4ohm 8omh 16 ohm the speakers need to match the amplifiers output to work properly. ...
Feb 21, 2015 | Soundstream Car Amplifiers
Soundstream pca2000d started smoking on me what do you think is wrong
well. if it doesn't function after smoking, then it needs to go to a GOOD technician. ( if one is available to you) if not then send it to soundstream. if this was not a good amp , I would advise getting rid of an amp that smoked, however soundstream is a good brand and deserves another chance. (always depending on the cost of repairs)
hope this helps.
Dec 29, 2013 | Soundstream PCA2000D Car Amp
Soundstream amp in safe mode
send it out to get fixed or sell it for parts. its damaged.
Oct 24, 2013 | Soundstream Picasso PIC2.440 Car Audio...
Best way to wire dual voice coil subwoofer to soundstream 880.2
Here is a link to the manual for that amplifier.. It shows you how to wire it up to just about any speaker combination.
Feb 26, 2012 | Car Amplifiers
Sound stream little wonder 62o. keeps tripping off for no reason its new only 3 weeks.spoken with other persons they have the same problem
Feb 19, 2010 | Soundstream Tarantula Car Audio Amplifier
I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
Don't know to conneect my amplifier connecting firdt a soundstream ecualizer
What are you running in to your amp? If it's a CD player or radio, find the wires from them, disconnect them from the amp and connect them to the equalizer, then connect the equalizer to the amp.
May 08, 2009 | Car Amplifiers
You can get the schematic from SoundStream. If you get the schematic and need help, email it to me at:
If the amplifier does nothing, post the DC voltage on each of the pins of the SG3525 (or whatever IC they're using in the supply). Use this as a template:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Nov 07, 2007 | Soundstream Davinici Car Audio Amplifier
Soundstream VGA400.2 Car Audio Amplifier Logo
49 people viewed this question
Top Soundstream Car Amplifiers Experts
Larry Spears
Larry Spears
ray gallant
Jay Plesset
Are you a Soundstream Car Amplifier Expert? Answer questions, earn points and help others
