Question about Dell Dimension 2350 PC Desktop
I need to put the start up power and leds on and i dont know how they r put ion the board l dimension 2350
    Novelist:
  • 166 Answers
First you need to go to the dell website and find a manual or guide to where to plug the wires into.usually you plug the cable into a strip of pins.they are usually at the front of the board.if you got
any more quesi need to put the start up power and leds on and i - 19153aa.jpgtions
just email me at gamecrazy944@yahoo.com
Posted on Jun 29, 2009
Dell Dimension 2350. After I shut it down and try
Check that the computer is not hibernating rather than shutting down. It will be in the power settings.
Mar 06, 2010 | Dell Dimension 4600 PC Desktop
Dell dimension 2350 won't boot, the psu fan comes on and the fan for the heatsink, the hard drive makes so noise what so ever and the disk drives won't open at all.
Depending on the Power and Diagnostic LED indications the system appears to be in a no post state. If the power LED is flashing Amber, the power supply is suspect. Solid Amber, indicates a motherboard problem. The Diagnostic LEDs on the back marked ABCD can give more specific POST error details.
Mar 05, 2010 | Dell Dimension 2350 PC Desktop
Configuring motherboard powerswitch leds reset
u will find front pannel connection pins on mother board. its in 2 lines. in onle row there is one pin slot idle. next to that vacant pin slot u insert reset sw, next to it insert hdd led, behind hdd led insert power led, next to power led (behind reset sw) insert power sw. thats it done
Jan 06, 2010 | Dell Dimension 2350 PC Desktop
2350 dead, not starting, just green flashing on board, no fans
Pull your hard drive and install it as a slave on another machine. If you can't read from it there, your hard drive is toast.
Oct 05, 2009 | Dell Dimension 2350 PC Desktop
Bluford E139765 mainboard power panel connector
Look at the board really close you'll see it at the bottom right corner, SPKR, RSW, PSW, and so on, try one at a time, until you get it
Jul 16, 2009 | Computers & Internet
Model name BLUFORD. E139765 motherboard. I need J16 pin layout for the power switch, reset switch, etc. Dell is not very helpful with this paticular board for some reason. Thank You for any info. DW
This is what I found after extensive searching,
......................O
.PWR LED- O O
.HDD LED- O O HDD LED+
.................... O O
.................... O O PWR LED+
...PWR SW O O PWR SW
.CON CNT O O CON CNT
Looks pretty lame, huh? I found this on Dell's Community Forum.
I gather, this motherboard was used in the Dell Dimension 2350.
http://support.dell.com/support/edocs/systems/dim2350/techov.htm#1101565
Looking, at what Dell has for the layout of the Dimension 2350 motherboard, there are 20 pins in the J16 header, just like he has crudely shown above. I don't see one missing in the corner, though. Of course, the link above is a crude example from Dell.
This person stated it was for the J24 header on the motherboard. Also stated that it was the Front Panel I/O header. (At least that's what was stated) I believe he was confused with the Control Panel header J24. Hopefully it is for the J16 Front Panel I/O header, as it has the Power On switch, HDD activity LED, Power LED, and so on.
Indications are that the O's represent the pins. There was a statement of taking -> Note, that there is a missing pin in the upper corner, and this orients the connector view, Orients, how you are looking at the connector. Only you will know for sure. I don't have this motherboard in front of me. Dell ISN'T giving ANY info out.
This person had the Bluford E139765 motherboard, in a Dell Dimension 2350.
The statement was also made, that there is a Brown jumper wire that connects the two CON CNT pins together, but didn't know if this jumper is required, as this person is putting this motherboard, into an aftermarket computer case. (?)
Solution?
What I would do.
I would have the power supply plugged in. I would use an LED lamp, with two wire leads attached to it. Leads of about two inches long, or more. (Borrow one out of the Front Panel, or from another parts computer?)
Twist the ends of the lead wires tightly. I would then touch the leads to two pins. Should they be power Out pins, (HDD activity lamp pins. Power LED pins, and so on), the light will light up, and not short out the two pins touched.
(If the LED light doesn't light up, no biggie. It just means the wires need to be reversed. Bear this in mind, when you go to hook the LED's up)
When the two pins for the Power On is found, the computer will turn on.
Judging by the crude diagram the missing pin is on the upper right.
Only you will know for sure, as the J16 header should have a flat place in one corner, where a pin would go. NO pin.
If so, this is what I see.
Processor to the left, PCI slots to the right, J16 header on the right, above the PCI slots. The header goes along the edge of the motherboard, lengthwise.
I'll number the pins like this.
Starting at the Top Left, and going down the Left side.
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19.
Starting at the Top Right, and going down the Right side.
NO pin, (Would have been Pin 2),
Pins 4, 6, 8, 10, 12, 14, 16, 18, and 20
Pins 3 and 4 are for the Power LED. (Confusion here)
Pins 5 and 6 are for the harddrive activity LED. PIn 6 is for the + wire/
NO connection to Pins 7, 8, 9, and 10
Pins 11 and 12 are for the Power LED.
(Which ones to use? Pins 11 and 12, or Pins 3 and 4? I leave it up to you to test as the computer is on, and see)
NO connection to Pins 13 and 14
Pins 15 and 16 are for the Power On switch.
NO connection to Pins 17 and 18.
Pins 19 and 20 are for that jumper wire he mentioned. I would try it without it. If the computer doesn't come on, or something doesn't work, like the harddrive for example, I would unplug the computer from power, then attach this jumper. Plug in, and see if everything works.
Apr 19, 2009 | Computers & Internet
Dell dimension 2350 shuts off after a few minutes
Definitely check the power supply fan and the CPU fan for dust. Overheating could be the culprit, good luck.
Mar 18, 2009 | Dell Dimension 2350 PC Desktop
Windows xp dimension 2350 sound card help
first right click my computer then properties
scroll done and you'll see your audio in there somewhere
if it's there then click on it and update driver
if it is not then I can tell you how to add your driver again
Jan 14, 2009 | Dell Dimension 2350 PC Desktop
No sound on my dell dimension 2350 pc desktop
Go to this Dell link and download the Audio driver:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_PNT_CEL_2350&os=WW1&osl=en&catid=&impid=
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell Dimension 2350 PC Desktop
Dell dimension 2350
if you use a flash light and a magnifying glass all the conection pins will be labeled ;like AUX in, for auxillary in which is usually for usb ports and plug and play items, then there will be a power reset set of pins for the reset button, and LED pins, and then your power should be labeled like wise. some times it wont be but you can look at the connector see if it has 3 or 4 wires and find the plug in that matches that has a u shaped metal place by it. its usually the power connection but if you are not sure take it to a professional so you dont cause damage.
Dec 08, 2007 | Dell Dimension 2350 PC Desktop
Dell Dimension 2350 PC Desktop Logo
42 people viewed this question
Alun Cox
