Question about Exercise & Fitness
Genki Treadmill, Model GK1305FI cuts out & ''E0'' error
I bought this treadmill 2nd hand. The seller said it needed a new board. At the time I googled treadmill boards and since it cost anything from $50 - $200, I thought $200 was a reasonable price to pay for a motorised treadmill. EXCEPT, I had no idea it would be THIS difficult to find someone to a) supply the board I supposedly need and b) someone who will fit it!? I don't know, maybe it doesn't need a new board. Would anyone know? Originally, it would speed up and double the speed you're doing and after a while it would come up with ''E0'' on the console. When I turned the machine off and then started it up again it would clear and all would be right again. It did this for a couple of weeks, but now it just shuts down - you might be a couple mins into your walk or 20mins! And it won't start again, except after a long (like a day or 2) break and then it would just shut down again.
There is a post on FixYa by ''tilliscream'' (get it? 'till I scream?? - I don't blame them!!) who had similar problems with their Genki treadmill. ''dytbb'' posted a possible solution. I visited spiritfitness site and called them. They couldn't help. They are not an importer or distributor of these treadmills and they don't know who is. I would hassard a guess that 'tilliscream' didn't find their solution here.... but I live in hope and who knows!, maybe enough time has passed that maaaybe someone out there knows either how to fix this or can supply the board - maybe even install it???.
Many thanks in advance to the person who might be able to help me fix my Genki treadmill.
  • 16 Answers
SOURCE: Life Fitness Treadmill "FET" error
Can you please provide model of unit.
Posted on Feb 20, 2010
  • 4 Answers
SOURCE: Treadmill seller in 'Nelson, Lancs' Need Help/Electrician.
07723 860145 i can help
andy
Posted on Feb 26, 2010
maxtreadmill
  • 832 Answers
SOURCE: Athlon iQ2 treadmill-just replaced motor control
If this is the same problem you had prior to replacing the MCB and speed sensor. I would check the drive motor, unplug unit then remove motor shroud then unplug the connectors leading to the motor itself. If you have wire leads and a 18v drill battery connect the leads into motor then attach the other end to you battery and if the motor will rotate ( approx. 1mph) , if it does the check speed sensor to see if the correct spacing between sensor and front roller ( check if the magnet has not fallen out of front roller pulley this also can cause you problems) hope this help!!
Posted on May 15, 2010
maxtreadmill
  • 832 Answers
SOURCE: I have the Nordictrack C2500, and for the second
You have a wire harness that attaches the upper board to the lower board. You may have to pull that harness thru the uprights ( Attach a fishing line so you can either pull a new harness thru or the original one ) and inspect it for snags crimps or broken wires also use a meter to a continuity check on the harness ends. Since the the command signals travel thru this harness also check all connections on the lower board. Its starting point
Posted on Jun 11, 2010
2manyhobbies
  • 129 Answers
SOURCE: shuts down when in use.
This sounds like a static electricity problem.
First, check your outlet for a proper ground connection.
Be sure that the ground pin on the plug has not been removed.
Depending on the model, a number of machines came with connecting clips to ensure that the upper console was grounded. They were installed during the time of assembly between the frame and console. Check your manual assembly instructions to see if yours is one of these, and check to be sure they have been installed.
Posted on Dec 30, 2010
Testimonial: "Not only the grounding screw was loose but also the surge protector that the treadmill was plugged into had been damaged by the loose connection."
Assembly of Genki motorised treadmill
Follow the steps carefully , indicated
by the user or installation manual
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 24, 2017 | Exercise & Fitness
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
Maxpro vibelife V815 treadmill error
go for free download: www. fitness.manualsonline. com or www. iconservice. com.
Test every connector and tight very well, see the fuse inside, see the diagram attached for reed swithc and speed sensor, clean and tight the connector very well.
run the software calibration for diagnose and troubleshooting.
Apr 29, 2012 | Exercise & Fitness
Treadmill GK1305FI showing E0 error on startup
Dear Sir:
This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1.
Use too the calibration software see under The Hood Motor instructions or use the user manuals.
sincerey. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 13, 2012 | Exercise & Fitness
L lost manual my manual for my GENKI TREADMILL
Please to http://manualsfactory.com
http://fitness.manualsonline.com
www.iconservice.com
sincerely.
E.CUADRA
MANAGUA,NICARAGUA C.A.
Nov 24, 2011 | Exercise & Fitness
I have a Proform 545s treadmill with incline and with ifit. When i start the treadmill it will no longer attain the programed speed. The higher the speed programed the fast the treadmill will go; however,...
It sounds a lot like it might be your Motor Control Board. You can find one used on varios websites (ebay if you're lucky). I found one for $149.00 on the following website:
http://www.treadmilldoctor.com/PROFORM-545S-TREADMILL-Motor-Control-Board
I hope you got a good deal on it because it seems to be quite an expensive part.
Thanks and good luck!
Mar 21, 2011 | Proform Exercise & Fitness
Genki Treadmill error 'ER'. Need tech details or contact.
I have a Genki treadmill that i cannot get fixed, so if you would like the safety key please contact me lisagidleyking@hotmail.com and i will send it to you.
Jun 09, 2009 | Exercise & Fitness
Genki treadmill that needs a service / repair
You might try looking under spiritfitness,com and click on the international dealer link. They do have a dealer in your country. I am not sure how far from you but they are somewhere there.
Apr 13, 2009 | Exercise & Fitness
Exercise & Fitness Logo
716 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
