Question about Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
    Scholar:
  • 30 Answers
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Posted on Jul 08, 2009
Lowrance 330c gps not responding
do you have both power and ground wires hooked up?
Jul 27, 2010 | Lowrance LMS-330C GPS Receiver
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Alarm says" gps module not responding"
"GPS Module Not Responding" is the display units way of telling you there is basically no GPS module connected. You didn't say which unit you have, so I am assuming this is something like an LMS-520? The GPS module is the LGC-3000? If this is the module you have, make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display. If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshootin guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
Apr 05, 2009 | Lowrance Lcx 28c Hd 7" Gps Fish Finder...
GPS module not responding
check the power connections to the antenna
Aug 23, 2008 | Lowrance LMS-330C GPS Receiver
Gps module not responding
can not be fixed from home. i'll have to send it back to lowrance. tried soft reset and hard reset, gps module not responding icon still pops up on screen, thank you for the suggestions.
Jul 11, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Was working fine,then i get mess.gps module not responding ???
hi,your gps module-antenna is powered into 12 volt same as unit,have you traced your cable-fuses etc
john
May 20, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Lowrance332
had same problem with lms337. i had upgraded the unit but had not upgraded the lms2000 gps module. i was turning the isolator on in the boat which powers up gps module, if the lms337 is not powered up as well the gps unit goes to sleep. the upgrade fixes it by checking that the unit has not been turned on periodically. otherwise as soon as you power up gps module also turn on lms337. lowrance product support sorted this for me.
Mar 02, 2008 | Lowrance LMS-332C GPS Receiver
Lowrance Lms 525c Df 5" Df Sonar Chartplotter With External Antenna Logo
607 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
