Question about Pioneer Computers & Internet
I have a SATA DVD/CD-RW 216D recorder with a PCI
I have a Pioneer SATA DVD/CD-RW 216D recorder with a PCI ATA card. everything seems to work except that it won't burn a disk. I get an error signal that there isn't sufficient room on the disk, even when it is new.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 162 Answers
It is the simple problem of your hardware you want to change your drive now
Posted on Jun 29, 2009
My pioneer dvd-rw dvr-k16m ata isn't playing music or dvds
Hi can you burn cds/dvds ? If not you can try to clean your dvd-rw. If that does not work is probably means its went to meet its maker and you will have to replace it.You can buy a new one for around £20.
May 10, 2010 | Pioneer DVR-107D DVD±RW Burner
Cant hook up my ata dvd burner to ata raid pci card
ata raid is used to connect HDD only, other devices doesn't work in raid mode as it refers to data storage method
Sep 22, 2009 | LG GSA H62N Super-Multi - Disk drive - DVD...
My pioneer dvr-k17b ata device failed instalation error code 39 could not load driver
1) uninstall your dvr from device manager
2) write REGEDIT at RUN
3) look for UPPERFILTER using search in the edit menu. After you have found it, delete this registry
4) repeat the same for LOWERFILTER
5) Go to the device manager, scan for hardware changes. Win Vista will now successfully install your DVR
Dec 26, 2008 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
DVD Drive does not start
cd opens, but dvd does not open or burns
Nov 24, 2007 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
PIONEER DVD-RW READS ONLY DVD BUT NOT CD
The CD laser has got dirty or failed
Try a driver cleaner if that does not work
replacement drive required
Nov 18, 2007 | Compaq Presario Notebook
Motherboard
Most of the new systems and motherboards support SATA connectors onboard. In your case there is none as you have found. So the best option is always upgrading to a new motherboard in case you need to add more SATA drives. You can also try to find SATA add-on cards, may a little costly types. These cards use PCI interface and very easy to install but hard to find one. I hpoe you could find one from a hardware store near you. If your motherboard has ordinary PCI slots then the SATA adpter will be less costly, otherwise (if it features a PCI-X slot) it will be costly. Following is a simple description on what the market has to offer: SATA II - 150 4Ports PCI-X with NCQ, Raid 0+1, Raid 0 and Raid 1 ! You can upgrade your desktop computer to have four Channels Serial ATA Generation 1 and Generation 2 transfer rate of 1.5 Gbps. The board provides a 64bit, 133 MHz PCI interface on the host side and four, fully compliant Serial ATA ports on the device side to access Serial ATA storage devices such as hard disk drive, ZIP drive, CD-ROM, CD-RW, DVD-ROM. Note: Fault tolerance: RAID 0 (Striping), RAID 1 (Mirroring), RAID 0+1 (mirrored-stripping) and RAID 1+S (Mirrored-Sparing) improve the data performance and provide the data redundancy and rebuilding.
Oct 09, 2007 | HP Pavilion 513n (P9850A#ABA) PC Desktop
Computers & Internet Logo
160 people viewed this question
Top Pioneer Computers & Internet Experts
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
