Question about Coleman Mach 15 Air Conditioner
Compressor on my RV coleman ac unit bogging down
When I turn my AC unit on it runs fine and cools down my RV. After 1st cycle the compressor sounds like it is trying to kick in but after about 40 seconds it stops and only the fan runs. About 3-4 minutes later the compressor tries to kick in but the same thing happens. This goes on and on unless I turn the ac unit off for about an hour and then when I turn it on it will work fine but only through the 1st cycle. Do I have a compressor issue? Do I need to buy a new unit?
  • 3 more comments
  • rwetzel56 Jun 29, 2009
    I'm not sure about head pressure or thermal breaker tripping. All I can tell you is that the unit bogs down after the first cycle. The unit cools down the first time but after that the unit won't cool down, it just tries.
  • rwetzel56 Jun 30, 2009
    Jeff,
    I noticed yesterday when testing this unit again, during the day when it is hot the unit ran fine. When it cools down in the evening, I noticed the unit wants to do this recycling thing. The fan on the unit runs when the compressor kits on and off. During the heat of the day the unit cools the camper and then shuts down and restarts fine when the thermostat calls for it. This is what has me puzzled. The amps are around 12.3 - 14.4 as the compressor runs and then it drops to 2.2 -2.3 when only the fan is running. Haven't checked the capacitor yet but will do that as well.
    Also, it is a 15,000 BTU unit made by Dometic Durotherm and not a Coleman.
  • rwetzel56 Jul 01, 2009
  • Ned C Cook
    Ned C Cook May 11, 2010
    excessive head pressure on ac pump.or thermal breaker tripping.
    Novelist:
  • 127 Answers
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Posted on Jun 29, 2009
  • Jeff Myers Jul 04, 2009
    Ok, the dometic units have the same start capacitor as the colemans. It is odd that it only does this in the evening. It cannot be a bad compressor if it works fine during the day. This is actually completely opposite of what usually happens on these units. The other it may be is a defective freeze control switch. The cold control is normally open (no continuity), and closes when the temperature of the evaporator is below 41 to 49 degrees. The switch will return to open at 52 to 62 degrees. So at temperatures above 62 the switch is open, below 41 it will be closed. If the parameters of your cold control are out of range, that would explain why it is doing it at night when the ambient temperature is greatly reduced. When you get a chance, take the cover off of the control box (in the return air of AC) and unplug the cold control. It is usually two white wires coming from above and plugged into a blue terminal on the board. If the unit runs fine that night, then you need to replace the freeze control.
    President:
  • 3,433 Answers
What does it do when powered by the generator? Or is this happening with 110? Do you have an invertoer on the system? 12v to 110? The reason is power supply issues. What happens on shore power? Any problems then? Has the unit been serviced or worked on recently? Is the fan outside (condensor fan) working? If it isn't it will cause high head pressures. Go topside and verify it is working, it can relly overtax the compressor.- good luck
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
May 09, 2010 | Dometic Rooftop RV Air Conditioner
Duo Therm AC Not Cooling
most likely a thermostat problem most rooftop air units fan will blow cont. and compressor cycles
Jul 26, 2009 | Heating & Cooling
AC Kicking OFF Breaker
Sounds like you have a problem with your compressor. If the beaker trips the second the compressor tries to come on hen it is shorted. If it takes a couple of seconds, then your compressor is locked up.
seth
Jul 03, 2009 | Dometic Rooftop RV Air Conditioner
AC is off but compressor cycles periodically
most likely your compressor contact is stuck closed, and will need to be replaced. if the fan also runs when the compressor comes on you may have a short between the t-stat and unit. hope this helps.
Jun 14, 2009 | Dometic Rooftop RV Air Conditioner
AC does not cool. Compressor kicks on and off (Humms when trying to start, electrical smell)
There are a couple possibilities:
1. If this is the first time you've started them for the season, one of the compressors might be seized up from sitting over the winter. In which case, new compressor required.
2. If you've just had the compressor serviced including recharging the system, it's possible that the system is simply overcharged. This will stop the compressor from working and giving you the same symptoms as above. If this is the case, you should have the service people come back with some guages and recover some of the refrigerant and the compressor should be fine.
3. If the unit has been sitting and there is a slow leak then there is not enough pressure in the system to allow it to run. The compressor will shut down if there is not enough pressure, but since you say there is a smell, i really doubt this is the case.
Most likely it's #1 or #2 above. If you haven't had it serviced recently, then yeah, it sounds like you're in need of a new compressor.
Good luck.
Apr 16, 2008 | Dometic Rooftop RV Air Conditioner
Coleman Mach 15 Air Conditioner Logo
1,282 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
