Question about Jenn-Air JGR8850 Gas Kitchen Range
Installation of down-draft exhaust duct for Jenn-Aire cook top
I have a Jenn-Aire cook top w/ grill. # JDS 9860 AAP MODULAR W/ DOWNDRAFT Bought about 1 year ago. Just trying to install it.The unit was stored and somehow the instruction were lost. Just need to know what type of duct is needed. Many thanks
Rush Button
  • 3 more comments
  • George Wes Dec 05, 2007
    I'm about to purchase the Jenn Air 9900 and want to know if I can do the downdraft installation myself. Where do I find the instructions for the installation of the downdraft...? George (jgwesoloski@ec.rr.com)
  • Anonymous Jan 06, 2008
    no duct work instructions on the Jenn Air website. it would be helpful since i plan to put the down draft cook top in an island - so the duct work needs to be done before the ceiling in the basement below goes up.
  • Anonymous Aug 26, 2008
    We have a Jenn-Air oven and want to put in an island with a cook top. We have a house on a slab and it has a second story. The island is about 6 feet from the oven and need to know your opinions on how to draft the island which will sit in the middle of the room.
  • anniestine Dec 23, 2008
    We have a problem with the vent on our Jenn-Air gas range.
    We have a crawl space underneath the house and the vent goes down through the floor and out the side. However, we are getting cold air back up through the vent, causing quite a draft. The flap on the outside vent closes and opens properly. What else could be causing this back air to come up form the outside??
  • Anonymous Feb 25, 2009
    My Jenn Aire is a downdraft through the slab to outside. Problem is this unit ducts off the unit back toward the cabinet wall with not enough space to us a 90 round duct. It must use some sort of flat rectangular duct that transitions to a round duct. Where do I get such a duct? Any ideas?
    Thanks,
    Randy
Minimal 6" duct no more than 20 feet long and 90's count as 5 feet. 90's must not be closer than 18" this will meet local codes regarding the venting also an approved exhaust hood. (not a dryer vent)
Posted on May 22, 2008
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to jennair.com and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Posted on Feb 11, 2008
SOURCE:
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
Replacing an old jenn air electric cook top with new 30" down draft gas cooktop. Need to know how to secure the cooktop to the granite countertop.
You should just be able to set the cooktop in after you attach the downdraft, usually there are tabs on the downdraft that clamp on to the granite cutout. There is probably a closed-cell foam strip that runs under the lip of the cooktop, I would just make sure it seals to the granite properly (no gaps) and put a couple dabs of silicone in between the lip of the cooktop and the granite. Usually the cooktop is heavy enough that the silicone will keep it from moving around.
StoneRepairman.com
Brandon@Stonerepairman.com
406.471.0000
Mar 25, 2011 | Jenn-Air 30 in. Expressions CCGX2420 Gas...
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Downdraft from exhaust fan
you definalty should feels air moving, providing hte unit is ON. when not in use there should be mo draft( minimal at best) if there is still a draft when unit is off, i would check where it exhausts outside, there should be flap tha closes when not inuse
Dec 21, 2008 | Gaggenau 36 in. CI491610 Electric Cooktop
Cold air draft
the only way is to block off/check the flapper., if your not going to use for the winter you can disconnect the vent from under the cabinet temporaily and close off there till you can gain access to check outside grill
Nov 25, 2008 | Jenn-Air JED8430 Electric Cooktop
Wiring problem
those wires dont go to the down draft. those colors are to hook up the stove. do you have the instalation instructions?
Nov 09, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Jan 13, 2008 | Jenn-Air JED8230 Electric Cooktop
Jenn-Air JGR8850 Gas Kitchen Range Logo
11,625 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
