Improper water flow: Either not enough or way too much!
You could have calcium or liming up in the internals of Heat Exchanger????
Remove the header/bucket of plumbing side & look thru the tubes of each one. Should be absolutely clear, if any residue buildup, there is your restriction. Needs to be cleaned.
I will include a link of diagram of the heater internals. Take a look at number 4. that is the exchanger, the part #45 is what you will remove to inspect the "Inside" of the heat exchanger tubes.
Good Luck
http://www.aqua-man.com/images/schematics/hseriesInducedDraft.jpg
Sounds like spider web in one or more burners
SOURCE: Hayward H300 Spa Heater will not fire up
try to replace the thermo sensor it is located on the left side of tghe unit and has 3 wires running to it.
SOURCE: hayward heater not staying lit
possibly poor pilot adjustment or insuficient mv output from thermopile
SOURCE: Hayward 250 heater won't fire up
Check the control circuit, specifically the pressure switch, for continuity with an ohm meter....any reading over 2 ohms needs to be investigated
SOURCE: My hayward heater fires up and then turns off
Thank you for posting your question here on Fixya.com.
The basics are covered in this excerpt from your owner’s manual. If you need direction or additional information about these steps please post your specific questions.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
SOURCE: Loud noises, shaking, visible white powder in chlorinator
See this page:https://sites.google.com/site/haywardpoolheater/
For info about the part that breaks and how to fix it. YMMV.
Sounds like the internal bypass located in the manifold for the water intake and exhaust lines has worn out or broke. Hayward sells parts to replace it. It is a lot cheaper than replacing the heat exchanger.
