Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Admiral LPF 2112ARW the cooler side don't get coolder
What is lpf switch
lpf is low pass frequency. You would want to have it turned on if you are running a sub off the amp.
Mar 26, 2012 | Pioneer GM-X962 Car Audio Amplifier
Admiral refridgerator freezer works fine but cooler section not cooling. had ice in back of cooler section.
it may be a timer and a timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32 also ...do not damage coils with freon in them
Aug 25, 2009 | Maytag Admiral Top-Freezer Refrigerator
Admiral side by side refrigerator ,model sal2027gbb
icemaker water valve is bad check to see if you can tell if the unit is turning
Apr 16, 2009 | Admiral 26 cu. ft. Side-By-Side...
Loose door handles.
There was a plastic card the size of a credit card that came with the refigerator that helps release the handles. If you don have this you can use any stiff plastic card ie: blockbuster card, store card etc...
Pull the handle away from you while inserting the card in the top or bottom of the handle based on your model. I believe the Admiral model LSD2615HEB required the card be inserted 11/16 of an inch. This should release the handle. Once released there are 4 hex screws located on the handle that may require tightening.
To reinstall: Match the hardware up just above the final location and then slide down, this should lock the handle back into place.
Feb 24, 2009 | Admiral 26 cu. ft. Side-By-Side...
Refrigerator side too warm
SHOULD HAVE A AIR DIVERT ER CONTROL TO SEND MORE AIR TO FREEZER AND LESS TO FRIG SIDE TRY TO SENT MORE AIR TO FREEZER SIDE AND LEAVE COLD CONTROL COLD ENOUGH TO ACCOMMODATE THE FREEZER SIDE TO BE COLD ENOUGH
Jan 28, 2009 | Admiral 26 cu. ft. Side-By-Side...
ADMIRAL SIDE BY SIDE COILS FREEZING UP
sounds like a defrost problem. most of the time it's the heaters behind the coils.
Aug 11, 2008 | Admiral 26 cu. ft. Side-By-Side...
My refegiator wont stay cold ,but my freezer gets cold my cooler grill gets like over iced and blocks the coolair from entering my refegiator .what to do. signed the admiral
Hi, for the meantime the admiral repair man not yet arrive you just defrost so that the ice will melted the cooling fan was shut off due to ice build up.
Jan 22, 2008 | Admiral 26 cu. ft. Side-By-Side...
Overtightened lpf knob
it seems like the POT is going to have to be replaced if it is broken, if the LPF won't adjust when you turn the knob eighter side then it is broken.
Dec 25, 2007 | Pyle PLA4240 Car Audio Amplifier
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
ADMIRAL REFRIGERATOR/FREEZER BURNED
admiral is a maytag owned company which is now owned by whirlpool. so contact maytag or whirlpool. google them should be eay enough to find..
Nov 02, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
48 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
